Old 04-01-2008, 06:34 PM   #31
Car: 08 DGM WRX STI
Fav Mod: Clear bra. For the car.
Default Re: Install AP now or wait?
Originally Posted by Digitalfiend View Post
As mentioned above my post, it could technically void your warranty, at least on the engine, but I'm willing to accept that since I've had no problems with my '05 and stage 1/2 (knock on wood) and secondly, my dealership is relatively mod friendly.
Not to suggest being underhanded with a warranty issue, but since the factory settings can be reinstated at any time with the Accessport, isn't a stage 1 flash pretty much between you and your car? Or does the ECU kiss and tell somehow?
DGMSTIenroute is offline   Reply With Quote
Old 04-01-2008, 07:06 PM   #32
Car: DGM 2008 STI
Fav Mod: Advan RZ DGM 18X9" +45
I think the main reason for this post is that I'm trying to reassure myself to go stage 1 without a boost gauge. I swore I'd never do something like that and on my '05 I had all my gauges first. Then again, a friend of mine has been running stage 1 on his car on the track without a boost gauge and his car is still running strong. Time to suck it up and just do it.
I did not know that its dangerous to go stage 1 without a boost gauge. Is it sketchy like that? or just paranoid people?
Oh and with the navigational system, cant you use that as a Boost Gauge aswell???
Old 04-01-2008, 08:18 PM   #33
Car: Gray 2008 STI
can't you use the AP as a real-time boost guage? If so, then once you get experience and trust with the new map, you could remove the AP and sleep well at night knowing Perrin did their homework properly.
mboulton is offline   Reply With Quote
Old 04-02-2008, 04:24 AM   #34
Fav Mod: protune by chris at XX
Send a message via AIM to tro8
has anyone added a Boost Gauge to there O8 sti yet? which one did you get and where did you put it...?? I like the look of these... kinda big and in your face, but so is the car..
japanparts.com : PARTS DATABASE
tro8 is offline   Reply With Quote
Old 04-02-2008, 06:28 AM   #35
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
I wouldn't say it is inherently dangerous, but I like to know when I'm spiking (not creeping) to 21psi. Obviously, a boost gauge won't show you if your car is pulling timing due to knock. Still, I tend to err on the side of caution but that's just me.
Yes you could, but that gauge only goes up to 18.x psi and our cars can easily spike above that given the tune, parts, conditions, etc. Personally, I'll be datalogging for the first few days of stage 1 as that is infinitely more useful than the AP's "live gauge" reading, which doesn't even have a MAX feature (unless they added that feature recently).
Old 04-02-2008, 08:45 AM   #36
Car: DGM 2008 STI
What difference does it make if its spiking to 21 psi... Like how would you be able to change and prevent that from happening? Also shouldnt the map your running keep it at a constant psi that you want to run ex: changing the 3 modes of the 08?
Old 04-02-2008, 10:13 AM   #37
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
Even if you set a boost target, it is possible for you to overshoot that target, which results in a boost spike and, in extreme cases, can lead to you hitting fuel cut. Overshooting can (obviously) lead to knock as well. It's not a major concern but as I said, I like to monitor things.
Old 04-02-2008, 12:31 PM   #38
Car: DGM 2008 STI
But what do you do if you do notice those spikes???
Old 04-02-2008, 12:37 PM   #39
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
Get the car Protuned (or do it yourself once the software is available).
Old 04-02-2008, 04:17 PM   #40
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
The other option is to use a different restrictor pill:
How Subaru’s Factory Boost Control System Works - COBB Forums
