Old 03-27-2008, 11:14 AM   #16
Car: DGM 08 STI
Fav Mod: cobb AP
Default Re: stock foglights upgrade to hids
Gil, when you did yours did you happen to notice how the foglight housing is attached? I'd like to pull them and paint them from gray to black, I imagine it would be easy.
Old 03-27-2008, 11:17 AM   #17
Car: White 08 STI
HIR 9011 for the highbeams. easy to modify to fit the highbeams. its a much needed improvement over stock 9005.
this is my second vehile i have fitted with 9011 HIR into the highbeams, and i will never go back to stock. its like the first time driving with HID headlights, you never go back to halogen unless you have halogen projectors.
talsnic is offline   Reply With Quote
Old 03-27-2008, 11:17 AM   #18
Fav Mod: Britax Roundabout
yes, it would be easy. once you take off the bumper, it's held in place with a couple of fasteners which you would screw off (heh, I said screw off, but I digress). Anyway, once you get the front bumper off, you'll see exactly what needs to be done to remove the housings.
Old 03-27-2008, 12:14 PM   #19
PCW
Originally Posted by GilMikalian View Post
Good alternative to HID for the high beam...although not speaking with first hand experience.
HIR Headlights 9011 9012 bulbs
GilMikalian/Talsnic,
Did you have to do any additional wiring fuses etc.., or just swap the bulbs for the foglights?
Thanks,
PCW
PCW is offline   Reply With Quote
Old 03-27-2008, 01:29 PM   #20
Again, I have not bought or used these bulbs, but based on what I've read, simple plug & play with no mods to wiring since the power draw is same as stock.
Old 03-27-2008, 01:36 PM   #21
PCW
Thanks,
PCW
No, Talking about the foglights.
PCW
Old 03-27-2008, 01:54 PM   #22
Woops No, no additional wiring for the fogs either, same 55W as the stockers.
Old 03-27-2008, 07:53 PM   #23
PCW
Thanks, just order some
Old 03-27-2008, 08:16 PM   #24
Car: White 08 STI
either HIR or other fogs can be used with no issues. they both pull the same amps. the extra light from HIR comes from the reflecting infered heat making the filiment hotter, thus more light.
