Old 03-21-2008, 05:03 AM   #1
Default Speedometer accuracy, spot on.
For those that care, I finally had the chance to compare actual speed to my speedo and was surprised at how accurate it was. Using a calibrated radar which was placed at the outside "apex" of a kink on a local street, I drove straight at the radar and registered 50 mph at 50 indicated on my speedo.
Maybe its the new electronic gauges, but what ever it is I'm happy to know how fast Im going now. My previous cars up until now have been off by as much as 5 mph at highway cruising speeds.
Cheers,
Chris
Old 03-21-2008, 06:07 AM   #2
Car: 07 Lexus IS250
Fav Mod: Future 09 STI Owner :)
Default Re: Speedometer accuracy, spot on.
I think the faster you go the more the speedo is off. So when you are hitting 130mph you are actually not going that fast.
chmura is offline   Reply With Quote
Old 03-21-2008, 06:08 AM   #3
Fav Mod: Cobb AP Stg1
Send a message via AIM to baneonrt
For those with nav you can enter a screen that shows you coordinates, which satellite you are using and your speed. I haven't yet remembered to open that screen before starting to drive but it should work well to compare your speedo to.
Steve
baneonrt is offline   Reply With Quote
Old 03-21-2008, 06:10 AM   #4
Car: 08 Dark Grey STi
Steve
That speed is from the VSS, not the GPS.
If you take a handheld GPS, you can compare the speedo's accuracy.
serendipity is offline   Reply With Quote
Old 03-21-2008, 06:18 AM   #5
Car: Silver 08 STI
Fav Mod: none...yet
Mine is right on as indicated by radar also.
T
trevoro is offline   Reply With Quote
Old 03-21-2008, 08:34 AM   #6
Speedos frequently indicate error in percentages. For instance, if you have a 10% error at 10mph indicated, you would be either going 9 or 11mph depending on which side of error youre favored on. If you were to have that same 10% at 100mph, you would actually be going 90 or 110mph.
When I ran by the radar (4x), I tried 35, 40 and 50. All of which were spot on. Now I imagine that if I were to crest 100 there will understandably be some small amount of error, but certainly not the 5% in my old cars. Maybe .5-1%. Not bad.
Old 03-21-2008, 08:42 AM   #7
Fav Mod: Volk RE30's and 255-35 Dunlop Z1's
I'll have to double check mine with my smaller than stock tires against my MaxQdata logger on the highway.
255-35-18's
I wonder if the ecu has the ability to adjust for smaller size tires??? I doubt it, but that would be cool.
ploney is offline   Reply With Quote
Old 03-21-2008, 09:16 AM   #8
Car: '08 RallyCross STI
Mine is spot on compared to the speed reading from my Garmin Nuvi GPS. My '07 Miata is also accurate as well. These are the first two cars that I've seen with accurate speedos, so I assume that the manufacturers don't have to do the 10% thing due to Europ legislation any more.
Josh@EpicSpeed is offline   Reply With Quote
Old 03-21-2008, 09:25 AM   #9
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
That's good to hear. The old cars were horribly inaccurate, even at 60 km/h.
Old 03-21-2008, 09:31 AM   #10
Can you confirm that you are correct? It seems to me that this screen is just the basic GPS data that is collected/calculated. There is no reason for it to come from the vehicle systems.
Steve
Old 03-21-2008, 10:01 AM   #11
Car: Blue 07 STI
Send a message via Yahoo to brantdw
I have an older Outback and 06 STI. I use a Tom Tom and the new Escort 9500i. Both of these tell the speed of your car. Both of them are consistanly 5mph off at almost any speed. Now I know why everyone in an outback is so Friggin slow.
brantdw is offline   Reply With Quote
Old 03-21-2008, 10:17 AM   #12
The 04-07 ECU was spot on, but the gauge displayed 2 or 3 mph high. It was so consistent that I'm pretty sure Subaru spec'd it that way.
Old 03-21-2008, 11:03 AM   #13
Send a message via AIM to midnit
Thanks for the news CFar... Currently in my05 anything over 40mph seems to be about 5mph off for me. Anything >100 is about 10+ off.
With Fairfax cops being how they are, I hate not knowing exactly how fast I'm going.
midnit is offline   Reply With Quote
Old 03-21-2008, 11:52 AM   #14
Trader Rating: (48)
The VSS in the older models was actually correct, but the gauges were wrong. I verified this on our 04 a few years ago with a hand held gps device. The speed is 4mph off at 80; hence the speedo is reading 84 when you are traveling 80.
I have compared my 08 at 80 against the speed read out from the AP and from my D3 and both indicate the speed to be only about 1mph high at 80.
Old 03-21-2008, 12:05 PM   #15
Car: 06 Aspen White STI
Fav Mod: Defi's
I'm glad that my speedo reads high. That way, I'm less likely to be actually speeding.
Iguana is offline   Reply With Quote
