Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Exterior
Old 03-15-2008, 10:36 PM   #1
jph
Car: the wagon
IWSTI Addict since: Apr 2004
Default replace high beam bulbs?
okay, this might be a silly question but ... bear with me for a minute
i'm not exactly happy with how the normal headlights are aligned.
and i'm not sure if adjusting them higher will help (but i will try this tomorrow)
so, my question;
is it possible to replace the high beam bulbs with a different type that allows you to drive with the high beams on, without blinding opposite traffic?
i'd like to get better visibility, especially light up the road further in front of the car. i can barely read traffic signs with the normal headlights at night.
J.
Old 03-15-2008, 10:45 PM   #2
Car: White 08 STI
IWSTI Addict since: Jan 2008
Default Re: replace high beam bulbs?
just aim the headlamps up, and you will love your HID. The stock aim is wayyy to low, and about 10 rotations with a screwdriver should do it.
You cannot run highbeams without blinding everyone.
talsnic is offline   Reply With Quote
Old 03-15-2008, 10:51 PM   #3
jph
Car: the wagon
i was going to try that
You cannot run high beams without blinding everyone.
that's why i wanted to know if i could change those bulbs with "non high beam" bulbs. and basically run dual headlight bulbs. effectively loosing my high beams.
J.
Old 03-15-2008, 10:55 PM   #4
Car: 03 Nissan Maxima SE
IWSTI Addict since: Aug 2007
J.
There's no such thing as a "high beam bulb." It is the design of the reflector which points the beam higher(if that made any sense).
MacAlert is offline   Reply With Quote
Old 03-15-2008, 11:00 PM   #5
jph
Car: the wagon
makes perfect sense! thanks. didn't know that
J.
Old 03-16-2008, 12:19 PM   #6
Car: 06 sti wrb
Fav Mod: trading the svt for an sti
IWSTI Addict since: Nov 2005
you can fit these in the hole, you`ll improve. but do more search before hand.
see bottom of page ««Halogen Infra Red 9005/HB3 Bulbs - 12V»»
http://http://www.rallylights.com/hella/9005.asp
the ambush is offline   Reply With Quote
Old 03-16-2008, 01:03 PM   #7
Car: White 08 STI
Done, and Done. 9011 fits very easily with a file. output is mucho better than 9005.
Old 03-16-2008, 01:35 PM   #8
How will changing the bulb make the high beams like the low beams, which is what the OP wants to do. The problem is the way the reflector is designed aiming the beam of the light higher.
Old 03-16-2008, 06:27 PM   #9
Car: 08 Subaru WRX STI
IWSTI Addict since: Aug 2005
I've done a search but can't seem to get a concensus on what replacement bulb is the best color matched for the low beam. Sorry if this hijacks the thread.
Portland Dave is offline   Reply With Quote
Old 03-16-2008, 06:33 PM   #10
Generally for high beams, you want something that is lower in the color scale (< 4300K). If you are looking to match, the color temperature you will want is 4300k.
Old 03-17-2008, 07:21 AM   #11
Car: 06 sti wrb
IMO more light is better, then just aim it where u want it.
Old 03-17-2008, 07:53 AM   #12
If I remember correctly, high beams cannot be aimed. Then again, I've never attempted to aim them as they are that way for a reason.
Old 03-17-2008, 11:22 PM   #13
Car: 06 sti wrb
usually the whole fixture is ajustable, horizontally, and vertically
