Old 02-28-2008, 08:08 AM   #16
issuer of points and bans
Car: 2004 STi
Default Re: 1st to 2nd shift..sucks! Upgrade pulley?
Originally Posted by JWA View Post
I haven't noticed that on mine, but what you describe sounds like it is a function of the ECU, not the flywheel to me. It's a common complaint on drive-by-wire cars.
+1
can be fixed with some tuning if you tell your tuner about it.
Old 02-28-2008, 08:33 AM   #17
Car: none
Send a message via AIM to Chiznarles
Originally Posted by Blip View Post
I learn on a old MG, no syncro's, No Problem on an 2006 S4
i tried learning that on my old celica but i kept grinding gears.. i would never try learning on an sti..
Chiznarles is offline   Reply With Quote
Old 02-28-2008, 09:17 AM   #18
Car: Silver 08 STI
Fav Mod: bald, smoking tires
Originally Posted by rj45 View Post
From what I've read, the throttle float between shifts is programed into the stock tune for emissions purposes; the cars run cleaner at higher rpm, so they don't let it drop between shifts.
Many stock cars have this problem, some more so than others. I heard that the first year of the new Honda Si had it pretty bad... there were so many complaints that I think Honda released an ECU update.
Exactly!
Many cars have this to pass emissions and the ECU does this when you chop out of the throttle, just as you do when shifting. The pulleys and flywheel wont really help this much, its a programming thing.
skark_burmer is offline   Reply With Quote
Old 02-28-2008, 12:57 PM   #19
Car: LYE DGM BBS/NAV
Fav Mod: Debadge, Fast and EZ.
If you look on the V8 S4 forums they have a problem with the RPM dropping to quick it is because the internals are really light to save weight to most of the accessories are driven off the timing chain that is why if you ask hear the the new ver of the 4.2 rev up they sound like they have a super charger that is how they more HP so you have to just left the throttle a little when you shift. That is really tricky
Blip is offline   Reply With Quote
Old 02-28-2008, 01:57 PM   #20
Fav Mod: Britax Roundabout
Alex, I would like to buy a comma.
Old 02-28-2008, 03:59 PM   #21
Coming from an MX-5, I'm just so blown away by the power, I hadn't realized. Is this something common to all cars then or is this a Subie thing? I wonder how much this affects 0-60 or 1/4 mile times?
Like I said, I'm not complaining. Given the power from the factory and the extra power extracted by the kind folks at Cobb, I'm as happy as [insert quaint saying].
Old 02-28-2008, 04:16 PM   #22
Car: White/Gold '08 STi
Fav Mod: Right foot
Originally Posted by JuggernautTCW View Post
beware of those lightweight pulleys... the missfire CEL...
how about lightweight flywheel upgrade
Please expand on the CEL issue for those of us who are new!
Old 02-28-2008, 04:19 PM   #23
Car: Blue Slate 08 G37S
Fav Mod: TBA...
Send a message via AIM to VtecSTI Send a message via MSN to VtecSTI Send a message via Yahoo to VtecSTI
IMO drive by wire is Gheyyy
VtecSTI is offline   Reply With Quote
Old 02-29-2008, 05:47 AM   #24
Car: Silver 05 WRX Sedan
Fav Mod: Stage 2 w/ Uppipe
heh... its a highly debatable topic whether a lightweight pulley throws CEL or not... some say stock is heavier since its a harmonic balancer some say subaru claims that the flat-4 balances itself... but either way some ppl have seen CELs after installing pulley and some dont... some swear it makes their cars faster and some dont feel a thing...
CEL from pulley and exhaust? - Transmission (AT/MT) & Driveline - NASIOC
Perrin Crank Pulley...worth it? [Archive] - NASIOC
different pulleys, different CEL's? [Archive] - NASIOC
and lots other threads. the CEL is more common on the wrx i think though.
JuggernautTCW is offline   Reply With Quote
Old 03-02-2008, 01:33 PM   #25
Driving the 08 that I got on Friday I think it is more of a shifter linkage porblem then a enging rev problem but I do agree it is a little tough. So Cobb here I come
Old 03-03-2008, 07:20 AM   #26
Don't own an STI yet but in my Mazdaspeed 6 I have the same 1-2 shift problem. My first gear is extremely short and I often find myself hitting 3-4k. If I don't wait that extra second on shifting to second the car shakes. 2-6 I can shift smooth and fast since the gear ratios seem to be much better between them. Or its the stupid drive by wire; threw me off gaurd when I put it on cruise control for the first time and the pedal moved back to its normal position.
Monoxcide is offline   Reply With Quote
Old 03-03-2008, 09:13 AM   #27
Car: 05 wrx--->07 STi
Fav Mod: teH bewstorz
Send a message via AIM to wacerx
how did you practice?... just shift without using the clutch?... thought that doesnt work anymore on modern cars?... last time i tried i got gear grinding...
(3rd to 4th example: easiest change to practice on)
run it up to 4k rpms, let off gas, apply light pressure towards 4th. you will feel it pop into neutral then into gear around 3k. apply gas and continue. works the same in every gear once you get good at it and it really isnt hard at all.
wacerx is offline   Reply With Quote
Old 03-24-2008, 04:36 PM   #28
Car: 08 Subaru WRX STI
Send a message via AIM to RAE129
This is a stock mapping issue. I had the same problem on my 2007. Once i flashed with gabedude's stage 1 maps, this issue no longer existed.
RAE129 is offline   Reply With Quote
