Old 02-27-2008, 12:56 PM   #1
Default Low beam headlight issues
I picked up my new 2008 STI yesterday. So far I am impressed, it is definitely more refined than my 2004 STI, except the low beam headlights.
It is hard to see where I am going in the dark desert night around here. The full beams are excellent but not much use when cars are coming at you. The pattern looks carefully engineered but does not throw light far enough out (I am using the 0 height setting already). Has anyone else noticed this or adjusted things to avoid crashing into stuff on the road more than 25yards ahead?
Thoughts/advice? I could find nothing on the forum with a search.
Some joker had set the rev limit buzzer to 2000rpm. As I drove off the lot and up the road there was a lot of pings and red lights. After consulting the manual it is now at 4000rpm for the break-in period.
Thanks
Philip
philrae is offline   Reply With Quote
Old 02-27-2008, 01:02 PM   #2
jph
Default Re: Low beam headlight issues
yup, noticed this too.
there's a thread floating around somewehre with some info on how to adjust them. i'll be attempting to do that this weekend.
J.
Old 02-27-2008, 01:06 PM   #3
JWA
They always come way to low from the factory. I noticed that you didn't mention that you have moved them up to the highest adjustment setting - you do know that there is a level adjustment wheel on the dash next to the illumination adjuster, right? Even still, you will likely need to adjust them up higher than the stock level. There's a thread here talking about it, but it only takes five minutes with a phillips screwdriver.
JWA is offline   Reply With Quote
Old 02-27-2008, 01:36 PM   #4
Car: Silver 08 STI
Umm... he DID day he was using the highest setting already. Link to the adjustment thread??
DrPhyzx is offline   Reply With Quote
Old 02-27-2008, 01:56 PM   #5
Car: White 08 STI
i just drove home, which is 900km. 4 hours of it was in the dark. i must agree, the headlamps were set too low, but after about an hour, i was able to adjust to the lesser light conditions.
this weekend the screwdriver will be my friend, and ill adjust them on a dark road. just like many other vehicles, ive adjusted.
i must say i love the ability to lower the lowbeams. ive had many fog drives where i wished that i could lower the beam to reduce glareback.
talsnic is offline   Reply With Quote
Old 02-27-2008, 02:01 PM   #6
Car: White 07 Acura MDX
Have you had projector style HID's before? They have a sharper cutoff than most people are used to.
pbm317 is offline   Reply With Quote
Old 02-27-2008, 02:29 PM   #7
LSE
Fav Mod: Defi Gauges
yup. i have this problem with my 06, but I'm just too lazy to adjust them. I actually have one slightly higher than the other one haha. shameless.
Old 02-27-2008, 02:42 PM   #8
Fav Mod: Britax Roundabout
Here is the link to the thread dealing with this very issue.
Low beam HID shine distance
Old 02-27-2008, 03:20 PM   #9
Excellent, thanks for the link. I guess I searched for "headlight" and so did not find it under "low and HID". I will try the fix later.
I like the idea of over correcting and setting it to 1 for normal use.
Philip
Old 02-27-2008, 03:57 PM   #10
Car: 08 STI (black)
Fav Mod: none yet...
Thanks for the link! This is something I've been meaning to look into The "highest" setting is ridiculously low from the factory. Funny, as the HID upgrade was one of the things I was looking forward to (from my 04 WRX). Glad to hear I'm not to only one who found this a problem. I'll be checking with my dealer to see if this is something they have specs for and will fix under warranty...
PS - Anyone else find it strange that the factory low beam pattern is staggered, being markedly higher on the passenger side?? I imagine this is deliberate, having more light on the headlight "further" away from oncoming traffic (at least when driving on a straight road anyway).... Wierd! I'm just glad this is something I can fix on my own.
PSS - Is there a guide/spec as to how high the low beam light pattern should be, so as to not blinding on coming traffic... something like 'park on level ground, XX feet away from a wall, then adjust your low beam height to YY feet up the wall??
BlueF is offline   Reply With Quote
Old 02-27-2008, 04:34 PM   #11
Car: Silver 08 STI
Fav Mod: bald, smoking tires
the lumpy headlight pattern is to give you better visibility for street signs and the like.
As for how far to adjust them, i simply drove to a large brick wall in a dimly lit area, turned my knob to 1 and popped the hood. i placed a towel over one headlight and adjusted the other with a 10mm wrench to make it easier to do one at a time. I was about 15' from the wall.
i just cranked them up to where i figured was just a little under horizontal and went for a drive. Bingo!
Since the headlights are rather low to the ground i didnt aim them down too much at all, besides if i load the back i can use setting 2,3,4...
skark_burmer is offline   Reply With Quote
Old 02-29-2008, 04:27 PM   #12
Can someone post a pic of the teeth screws please? My problem is worse, I think my lamps were adjusted for a JDM car, the driverīs side is much higher than the passengerīs, but still very low. I need to correct that asap.
On another note, I drive in less than perfect roads and I know that HIDīs have some kind of suspension system for protection, but Cīmon, this is ridiculous, the bouncing is driving me crazy. Has anybody else noticed this, or is something wrong with my HIDīs.
MEXSTIMPREZA is offline   Reply With Quote
Old 02-29-2008, 04:38 PM   #13
No I get the bouncies too. It is annoying but I guess I've gotten used to them. Sorry can't help with the picture of the teeth as I have yet to get in there to adjust.
Old 02-29-2008, 05:12 PM   #14
Car: Black on Gold 08 STi
Fav Mod: ...
I already adjusted my low beams up alot more. It's real easy to do.
Mediumturbo is offline   Reply With Quote
Old 02-29-2008, 05:30 PM   #15
Car: 08 Gray STi
Without the anti-shock mounting your HID capsules wouldn't last worth flip. If you've spec'd out replacements they tend to be pretty spendy.
BTW: Update on 08 STi adjustments added to the other thread.
