Old 02-19-2008, 10:01 PM   #1
Car: 08 STI and 07 R6
Default viberating hood on 08 STI?
I notice vibrations on the hood when hit uneven pavement or on the highway. Just wondering is the normal on a Subaru? Thanks.
HRCboy is offline   Reply With Quote
Old 02-19-2008, 10:04 PM   #2
Car: White/Gold '08 STi
Fav Mod: Right foot
Default Re: viberating hood on 08 STI?
I noticed that too. Its funny how bad it is. I think Ill get used to it but it seems weird that there arent stoppers in there to limit movement of the hood.
Old 02-19-2008, 10:07 PM   #3
Fav Mod: CAR LIFT & Protune!
normal, just make sure its latched...
this is the hood scoop pulling air into the engine bay for the TMIC
Old 02-19-2008, 10:28 PM   #4
Cools so it's normal... First car with a hood scoop so just wondering if it's normal. I asked my friend if his Legacy Spec B does it and he says no.
Kind of annoying if you ask me. I wonder if there a solution for this?
Old 02-19-2008, 11:49 PM   #5
Car: Black 2008 STi
Send a message via ICQ to RPI-STi Send a message via AIM to RPI-STi Send a message via MSN to RPI-STi
this scared the living bejesus out of me when I first drove it on the highway after purchase. Pulled over and checked everything out under there. It is because of the massive airflow gong through the scoop and cause the hood is aluminum.
RPI-STi is offline   Reply With Quote
Old 02-19-2008, 11:54 PM   #6
Car: PSM 04 WRX
haha same here... i have a cf hood and when i started to hit about 50mph+ on th efree way thing starts to move like crazy and i get scared its going to pop open but nothing happens... i tried to move up the rubber stoppers but it doesnt do much
xhengmanx is online now   Reply With Quote
Old 02-19-2008, 11:55 PM   #7
I don't mind the vibration cause it's a fantastic car to drive but if they are aim more for the mature BMW crowd...things like this should be addressed.
Wondering if placing some rubber grommets at the corners would help?
Old 02-20-2008, 04:34 AM   #8
Trader Rating: (47)
The 08 is much better than the 04 was with this. My 04 with the aluminum hood and larger scoop flops around like mad on the highway. The 08 is not that bad.
Tony
Old 02-20-2008, 06:00 AM   #9
Car: DGM 08 STI
Fav Mod: cobb AP
Wow, I've never noticed this on mine... guess I should drive faster
Old 02-20-2008, 07:00 AM   #10
Car: 08 specB
Send a message via AIM to denver133
My Spec B hood is probably 10 lbs heavier then the STi hood. I also don't think the scoop is "sucking in as much air" (as my wife says) whereas the STi's scoop looks larger.
denver133 is offline   Reply With Quote
Old 02-20-2008, 12:05 PM   #11
Car: 07 OBP STI
the new 08 hood looks hot and aggresive with its "in-bound" scoop i guess you can call it rather than the previous years' sticking up scoop. anyone know if the 08 one would directly fit onto an 07?
Old 02-20-2008, 12:22 PM   #12
Car: 08 Gray STi
interesting, since i'm still breaking mine in, 4k rpm is only 100 mph in 6th. but up to that point, i didn't notice it on mine.
Keep in mind my only other reference is my '03 WRX that looks like kids on a trampoline in comparison.
Old 04-10-2008, 05:58 AM   #13
Car: STIzzle
Fav Mod: Tint
Lightbulb Re: viberating hood on 08 STI?
I couldn't disagree with this more. It looks as though the entire hood lifts several inches when you hit a bump. This has nothing to do with ram air velocities. Our hood scoops are integrated into the hood design so it isn't the scoop that is moving, but the entire hood.
I freaked out the first time I experienced this...it certainly grabs your attention.
It is not a bonnet, it is a hood you ******* wanker.
Old 04-10-2008, 07:27 AM   #14
Car: 08 STI
Fav Mod: Removing the window sticker
This doesn't happen on my car. The roads around me a garbage and I don't see any movement.
tshrey is offline   Reply With Quote
Old 04-10-2008, 07:38 AM   #15
Car: AspenWhite 08 BBSNAV
Fav Mod: Red Tail Overlays
No movement here either.
RoninHatch is offline   Reply With Quote
