Old 04-10-2008, 08:07 AM   #16
Car: STIzzle
Fav Mod: Tint
Default Re: viberating hood on 08 STI?
Originally Posted by tshrey View Post
This doesn't happen on my car. The roads around me a garbage and I don't see any movement.
It happens to me when I am on the interstate and hit a bump at about 80mph.
Old 04-10-2008, 08:10 AM   #17
Fav Mod: wingless and mis-fires
Send a message via Yahoo to toogood
Originally Posted by RoninHatch View Post
No movement here either.
you guys must have the special edition versions then with no play on the hood.
theres going to be alot of things that you guys arent going to be used to..wait till you start hearing noises you've never heard before
toogood is offline   Reply With Quote
Old 04-10-2008, 08:14 AM   #18
Car: STIzzle
Fav Mod: Tint
+1
Old 04-10-2008, 08:21 AM   #19
Car: 08 STI
Fav Mod: Removing the window sticker
Oh, I've got plenty of weird noises, but most of them are mechanical and I've been able to identify them.
Good to see that after a complete redesign of the back end they kept the really cool diff clunk when you launch the car
tshrey is offline   Reply With Quote
Old 04-10-2008, 08:21 AM   #20
Car: DGM 08 STi
Yeah, my '05 did it too. Normal (the hood that is.) As far as noises, my '08 is a lot quieter than my '05. It still makes some standard STi noises (tranny, brakes, diffs, etc) but overall a much better ride. And it handles better to top it off!
-rain-
raindance is offline   Reply With Quote
Old 04-10-2008, 10:37 AM   #21
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
Speaking of noise, my STI on cold startup sounds very loud at idle. I don't recall my '05 being THAT loud but I know there are a couple additional environmental components that my '05 didn't have. Is it normal, on cold startup, for the '08 to make a relatively loud whirring noise? Believe me, I'm comfortable and totally familiar with the boxer ticking and clacking, but this noise sounds different. Normally it wouldn't bug me, but with that stop sale order, I'm a tiny bit paranoid.
Another thing: I actually find my '08 to be rather growly at 2-3K RPM. As soon as I hit 3K it turns into the normal boxer growl, but below that it sounds a bit more metallic/raspy. Once again, it's probably just me being paranoid but it reminds me of my '05 with Cusco mounts, but without the vibration.
As for the hood, mine doesn't move that much at all. But I haven't done any highway driving yet (just a few bursts up to a little over highway speeds.) My '05 hood lifted noticeably at speed.
By the way, according to Subaru of Canada, the STI hood is still an "aluminum alloy" and still feels very light (even with the hood struts.)
Old 04-10-2008, 10:40 AM   #22
Fav Mod: A new motor for this POS
It seems like the rubber stops that the hood sits on are very soft, allowing the hood to bounce up and down even while latched.
Old 04-10-2008, 11:05 AM   #23
Fav Mod: Recaros
I'd say not normal -- I've never seen any vibration or movement of the hood on my '06 except on the track, and then only at 100+ mph. IMO check the adjustment on the hood to make sure it's resting firmly against the bumpstops when closed.
Old 04-10-2008, 11:20 AM   #24
Mine does not viberate a (unknown measure here), but it does vibrate a little.
By the way, please do not start any more threads of little things that if not for the threads, we would have never noticed them (rear view mirror to low, hood viberating, etc).
MEXSTIMPREZA is offline   Reply With Quote
Old 04-10-2008, 11:48 AM   #25
my hood lifts up so bad you can see my the battery and my intake!!!
jk
Old 04-10-2008, 12:09 PM   #26
Car: AspenWhite 08 BBSNAV
Fav Mod: Red Tail Overlays
You mean like that loud clunk when pulling out of reverse into first in the morning? or the brake grind?
RoninHatch is offline   Reply With Quote
Old 04-10-2008, 12:18 PM   #27
jph
Originally Posted by RPI-STi View Post
this scared the living bejesus out of me when I first drove it on the highway after purchase. Pulled over and checked everything out under there. It is because of the massive airflow gong through the scoop and cause the hood is aluminum.
just FYI, the '08 hood is STEEL.
J.
Old 04-10-2008, 12:41 PM   #28
Car: E31, 08 DGM STI
I was half way through a response when I noticed the "JK". Nice work on the light yellow
darrenbt is offline   Reply With Quote
Old 04-10-2008, 12:50 PM   #29
Car: 08 STi, SSM
Whirring at startup is probably that air pump which was implemented to reduce cold start emissions
Old 04-10-2008, 01:49 PM   #30
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
That's kind of what I figured (was hoping).
