Old 02-28-2008, 04:59 AM   #61
Car: 08 Dark Gray STI
Default Re: My Stage 1 COBB OTS Results
Just installed the Cobb Stage 1 last night. If there is anyone thinking about going stage 1... DO IT!!! There is a noticeable difference between stock and stage 1.
NC2008STI is offline   Reply With Quote
Old 03-06-2008, 11:34 AM   #62
jph
Originally Posted by Spork View Post
It stayed around 18.1 but did hit 18.7 on one of the pulls.
kinda late... but going to ask anyway
is this a Cobb map, or a custom pro-tune ?
because boost targets on the stage1 cobb map should be around 16psi or so. and that's waht i seem to be getting on mine. a spike to 17-ish for a slint second, then it settles down to 16 psi.
J.
Old 03-06-2008, 11:44 AM   #63
Car: AW 08 STi
Fav Mod: snow tires
This is the COBB Stage 1 off the shelf 93 octane map.
Spork is offline   Reply With Quote
Old 03-06-2008, 11:56 AM   #64
jph
looks like you're right on target. should have checked the map notes first
Boost Targets:
~17.8psi peak boost pressure tapering down to ~13.5psi by the 6700
RPM redline, +/- 0.8psi.
damn our 91 octane!!!!
J.
Old 03-06-2008, 12:55 PM   #65
Car: 08 Aspen STi Hatch
Fav Mod: Stage 2 AP
very nice. with the Stage I we can stay pretty much stock otherwise then?
HASTIhatch is offline   Reply With Quote
Old 03-06-2008, 01:12 PM   #66
Car: 07 Lexus IS250
Fav Mod: Future 09 STI Owner :)
Originally Posted by parkergc8 View Post
Originally Posted by Digitalfiend
08 STI map download page. cobb . wrx sti accessport . map listing
In that link what is the difference between the Cobb Stage 1 91 Octane map and the Cobb Stage 1 91 Octane map specifically for AZ/CA/NV??
Since they are both 91 octane maps why have a difference? What are the pros/cons of either?
chmura is offline   Reply With Quote
Old 03-06-2008, 01:55 PM   #67
jph
read the map notes;
Description: Stage1 91 v100 - Intended for an otherwise stock
vehicle with a stock or cat-back exhaust, STOCK INTAKE SYSTEM and
STOCK INTAKE FILTER ONLY. 91 or 92 octane fuel. Boost Targets:
~16.5psi peak boost
Description: Stage1 ACN91 v100 - Intended for an otherwise stock
vehicle with a stock or cat-back exhaust, STOCK INTAKE SYSTEM, and
STOCK INTAKE FILTER ONLY. Arizona, California, or Nevada 91 octane
fuel. Boost Targets: ~16psi peak boost
~13.5psi by the 6700 RPM redline, +/- 0.8psi.
J.
Old 05-11-2008, 03:35 PM   #68
Car: AW 08 STi
Fav Mod: snow tires
Update: Same dyno, about 20 degrees warmer out, no further mods. 2200 miles on the car, it put down 241.4 this past weekend. I'll post up a pic of the dyno sheet Friday when I return home.
Old 05-11-2008, 05:16 PM   #69
Car: 2008 DMG STi
Originally Posted by RallySportDirect View Post
Guys with a Stg2, and Catless Down Pipes.
GET A BOOST GAUGE!
After installing a Catless down pipe, and Stg2 map. Our car was hitting 22PSI! Do to the lack of back pressure. And this was on the 91 Octane map.
We ended up enlarging the stock boost pill to .041(at different altitude you might need to do a different size) and the boost went back down to 17psi. And that is where it should be with a stock Cat back.
Be carefull running a Catless downpipe, OTS Stage2 map and no boost gauge to monitor.
Another thing. The AP will only read up to 18.6PSI, even if you are hitting 25PSI it will only show 18.6
Kirill
RallySportDirect.com
Would changing this pill be an alternative to porting the wastegate??
1day is offline   Reply With Quote
Old 05-12-2008, 05:56 AM   #70
Car: 05 STi CGM
Fav Mod: snowboard
34 hp and 40 TQ are very nice gains from a flash only.
That initial stock dyno of 199 is hurting though.
Riggs is offline   Reply With Quote
Old 05-12-2008, 05:58 AM   #71
Car: AW 08 STi
Fav Mod: snow tires
It's higher than that now and I bet if I went back to stock, it would be higher than 199. It's up 42 HP as of Saturday, no new mods, just more mileage.
Old 05-12-2008, 09:17 AM   #72
Car: DGM 2008 STI
Fav Mod: Soon Accessport
I bet if you drove it hard from the beginning your stock horsepower would of been more.
