Old 02-21-2008, 11:25 AM   #46
Fav Mod: Britax Roundabout
Default Re: My Stage 1 COBB OTS Results
Originally Posted by CFar View Post
Have any of you that have an accessport used I mode? If so what is the part throttle feel? What is the difference in general?
I mode in Stage 1 is very similar to stock. Admittedly, I have not been in I since I got the AP BUT when I did go into it, it felt about the same as stock.
Old 02-21-2008, 12:39 PM   #47
Car: STI's ;)
Fav Mod: Coolest Vendor Ever
Send a message via AIM to RallySportDirect Send a message via Yahoo to RallySportDirect
Guys with a Stg2, and Catless Down Pipes.
GET A BOOST GAUGE!
After installing a Catless down pipe, and Stg2 map. Our car was hitting 22PSI! Do to the lack of back pressure. And this was on the 91 Octane map.
We ended up enlarging the stock boost pill to .041(at different altitude you might need to do a different size) and the boost went back down to 17psi. And that is where it should be with a stock Cat back.
Be carefull running a Catless downpipe, OTS Stage2 map and no boost gauge to monitor.
Another thing. The AP will only read up to 18.6PSI, even if you are hitting 25PSI it will only show 18.6
Kirill
RallySportDirect.com
RallySportDirect is offline   Reply With Quote
Old 02-21-2008, 06:06 PM   #48
Car: 08 STI and 07 R6
Werd on the heads up!
I have reflashed my 08STI back to Stg 1 93 octane. Stage 2 gave me a Code of 244 which is overboast and I quickly flashed the ECU back to Stage 1 93.
The car doesn't throw the 244 code anymore but my AP reads peak PSI of 18.7 which has me worried about your comments regarding the accuracy of the AP.
Is enlarging the stock boost pill the only fix or can some get a custom tune to correct this problem?
Thanks.
GET A BOOST GAUGE!
Kirill
HRCboy is offline   Reply With Quote
Old 02-21-2008, 07:55 PM   #49
Car: STI's ;)
We also got the same CEL.
If you replace the restrictor pill, you can lower your boost.
http://www.cobbforums.com/forums/ima...mWorksv109.pdf
A custom tune will take care of that issue as well.
One thing. You might be running way more boost then you are seeing. As the AP will not display over 18.XX PSI.
Order the restrictor pill from a local dealership. And try not to drive the car.
Also read this.
http://www.accessecu.com/accessport/...091%20v100.pdf
Old 02-21-2008, 10:04 PM   #50
jph
i'm on the cobb stage1 map.
I : feels like the car is running on Nyquil
S : normal behavior
S# : feels JUST RIGHT! very responsive.
J.
Old 02-22-2008, 08:08 AM   #51
Car: 2008 SSM Sti
Fav Mod: Just Getting Started.....
I'm not sure why anyone would run a catless DP w/ a COBB OTS Stage 2 map. It specificaly states that you should not run this set up. You have to run a catted DP.
ssauer2004 is offline   Reply With Quote
Old 02-22-2008, 08:19 AM   #52
S : normal behavior
J.
Great, thank you
Old 02-22-2008, 07:14 PM   #53
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
You aren't running that stage 1 map with a catless downpipe are you?
Thanks.
Old 02-22-2008, 07:20 PM   #54
i eat cones
Fav Mod: catless
i hope not hehe.
but anyways, DSG's dyno is relativly low reading.
Old 02-22-2008, 10:34 PM   #55
Yes I am... I was told it will be fine. No engine light and I'm drive pretty tame till I get the wastegate ported and a custom tune next week.
Impressions : 08STI w/ Cobb Accessport and RR catless DP. - Page 2 - Vancouver Impreza Club Forum -- VIC - NASIOC
Old 02-26-2008, 08:52 AM   #56
Car: 06 WRB STI
Fav Mod: Volk Racing RE30 (Diamond Black)
any new news on numbers tune etc?
TheHammer is offline   Reply With Quote
Old 02-26-2008, 08:55 AM   #57
Car: 1998 Impreza GF8
Send a message via MSN to RFFG
Nice #'s, car looks good!!
RFFG is offline   Reply With Quote
Old 02-26-2008, 03:55 PM   #58
Car: WR blue 08 STI
Send a message via MSN to Swede Send a message via Skype™ to Swede
I believe 244 Code is overboost.
P0244Turbocharger/Supercharger Wastegate Solenoid A Range/Performance
Swede is offline   Reply With Quote
Old 02-26-2008, 04:27 PM   #59
Car: AW 08 STi
Fav Mod: snow tires
Thank you!
Spork is offline   Reply With Quote
Old 02-26-2008, 06:57 PM   #60
Heres an expression of what the stage one map is for you.
BAD BAD BAD!!!
The minimum requirment for the stage one map is a stock downpipe. You need to be running the stage two map.
You have to mechanically tune your boost control system to run the spec boost. Just like Rally Sport Direct has told you to.
Not to jump on you but if you read the map notes (list allrequirments and necesary specs) on the download page, you can help yourself a lot. I'll link it to you.
Knowing the notes for your particular map should be important. by knowing your map notes you can quickly get a very good grasp for how your car is running.
Heres the link to the map download page. If you can't read pdf files you will need the adobe pdf reader software. It's worth the download.
08 STI map download page. cobb . wrx sti accessport . map listing
parkergc8 is offline   Reply With Quote
