Old 02-19-2008, 06:32 AM   #31
Car: AW 08 STi
Fav Mod: snow tires
Default Re: My Stage 1 COBB OTS Results
Here you go
cobb . wrx sti accessport . map listing
Spork is offline   Reply With Quote
Old 02-19-2008, 08:09 AM   #32
Car: Silver 05 WRX Sedan
Fav Mod: Stage 2 w/ Uppipe
Originally Posted by Pre View Post
You don't know anything man.
Originally Posted by serendipity View Post
Every dyno is different. Some are heartbreakers. A dyno is only a tuning tool, useful to see the change caused by some modification - in this case the AP map.
actually i went to Dent Sport Garage to tune my WRX as well (same place as where Spork went, so Im assuming its the same dyno)... I was indeed told by them that stock a STI usually puts down 220 on their dyno. 199 is indeed on the low side...
JuggernautTCW is offline   Reply With Quote
Old 02-19-2008, 09:13 AM   #33
Car: 08 STI and 07 R6
Originally Posted by Spork View Post
The stage 2 map states that it is intended to be used with a catted downpipe. What is the description of the 244 code? Cat efficiency?
I believe 244 Code is overboost.
HRCboy is online now   Reply With Quote
Old 02-19-2008, 09:34 AM   #34
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
If you have a catless exhaust and with the current temperatures, that isn't surprising that you are overboosting on the stage 2 OTS map (which is for a catted downpipe.) I would highly recommend that you find a Protuner to touch up that map for your specific needs.
Old 02-19-2008, 09:42 AM   #35
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
Here is the boost file
Man look at how much better the AFRs are under boost compared to stock! 12.x:1 at 15psi (across 1000rpm) vs 10.5:1 at 18psi. Still pretty rich, which should mean relatively safe and that there is more power to be had by leaning it out a touch more. Still, as a temporary fix for the crazy stock tuning, AP stage 1 looks like a winner.
Old 02-19-2008, 09:48 AM   #36
Default Afr/idc
DigitalfRiend finally touched on the question I was going to ask:
The tune looks a bit safer with the AFR. Did they just get an ECU reading for that, or did they plug in a wideband somewhere?
Also, did you happen to log the injector duty cycle before and after to see what they are doing?
Old 02-19-2008, 09:50 AM   #37
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
Default Re: Afr/idc
Originally Posted by CFar View Post
Digitalfriend...
Digitalfiend...no 'r'.
Old 02-19-2008, 10:18 AM   #38
Default Re: Afr/idc
I changed it in my original post...because I think of you as our digital fRiend on the board. WAH Wah wahh. Laying out the Velvetta, all day every day...
Old 02-19-2008, 11:18 AM   #39
Car: AW 08 STi
Fav Mod: snow tires
Default Re: Afr/idc
There was a wideband plugged in, I do not have IDC's though.
Old 02-19-2008, 11:29 AM   #40
Default Re: Afr/idc
Thanks. Ill see what I can dig up with the IDC's when Im broken in.
Old 02-19-2008, 12:14 PM   #41
Car: 07 MZ4,08 STI
How is the SI drive system affected in any way?
Is the gain only noticeable in "S#" mode?
Can you still use "I" and " S" mode setting to change the throttle response?
freeman is offline   Reply With Quote
Old 02-19-2008, 12:17 PM   #42
Car: AW 08 STi
Fav Mod: snow tires
On the Dyno there was no difference in the numbers with the exception of the I mode seeming to cut the throttle at 6000 - 6500 rpm, can't remember exactly.
Old 02-19-2008, 12:44 PM   #43
Fav Mod: Britax Roundabout
Per COBB, the functionality of the SI-Drive is retained by each map. So for any given map, the I & S are notched down in the same proportion from S# the same as they are in stock form.
Old 02-19-2008, 01:41 PM   #44
Car: 06 WRB STI
Fav Mod: Volk Racing RE30 (Diamond Black)
I got 260.8 Stg 1 on my 06 STI on this same dyno.
Good group of guys @ DSG!!
TheHammer is offline   Reply With Quote
Old 02-21-2008, 11:20 AM   #45
Have any of you that have an accessport used I mode? If so what is the part throttle feel? What is the difference in general?
