Old 01-27-2008, 03:41 PM   #1
pwn
Car: WRB 08 STI
Fav Mod: Only one - Cobb AP
Send a message via AIM to pwn
Default 08 Rear strut tower brace
How are we going to be doing this? Obviously with the wrx wagons it just went straight across the back, but that gets in the way etc. Are there any brace ideas floating around, or perhaps someone will create an easy snap on snap off design for people that want to remove it in order to make use of the rear cargo area? Any ideas?
pwn is offline   Reply With Quote
Old 01-28-2008, 03:56 AM   #2
Default Re: 08 Rear strut tower brace
Not sure a brace really matters all that much. The STi already has a stouter chassis than the WRX. What a brace does for them is likely imaginary anyway.
A cage be noticeable on the other hand
Old 01-29-2008, 05:32 AM   #3
Car: 08 STi, SSM
i don't know if you took a good look at the 08 suspension but it's mounted entirely on a sub-frame which is then bolted to the uni-body. The sub-frame absorbs the stress from the suspension, pretty much negating the need for a rear strut tower bar (there are no more real strut towers).
Old 01-29-2008, 10:42 AM   #4
pwn
Car: WRB 08 STI
Good point, my brain must have been farting when I posted this up. This is also the reason for the wider cargo area! Doh.
