Old 12-10-2007, 09:01 PM   #1
Car: 05 Subaru WRX STi
Fav Mod: Cobb TBE
Default IC spray
Will the 08 have the IC spray?
gregginns is offline   Reply With Quote
Old 12-10-2007, 09:41 PM   #2
Car: 04 java black WRX
Default Re: IC spray
no improved air flow and a larger (i think 10% larger) ic negate the needs for the spray, sad day.
philswrx04 is offline   Reply With Quote
Old 12-11-2007, 09:33 AM   #3
Car: 06 Subaru WRX STi
Fav Mod: My right foot...
Well, I don't think that the IC spray does anything significant. It just sounds good.
pantag is offline   Reply With Quote
Old 12-11-2007, 09:37 AM   #4
Fav Mod: Carlabs X-brace & RPM brace
I think it works well when you are sitting in traffic and getting lots of heat soak otherwise I don't imagine it helping much.
My IC switch is now spraying my windshield as my windshield tank is now for 50/50 meth/water
hoffit is offline   Reply With Quote
Old 12-11-2007, 10:13 AM   #5
HowTo Contributor
Car: 06 Aspen White STI
Send a message via AIM to Shakes Send a message via Yahoo to Shakes
IC sprayer makes worlds of difference if you actually use your car.
Shakes is offline   Reply With Quote
Old 12-11-2007, 11:26 AM   #6
Car: black 05 Sti
I think it's really made a difference, especially on hard runs (on private roads, in front of schools), and the track
AMTEXX is offline   Reply With Quote
Old 12-11-2007, 01:57 PM   #7
pwn
Car: WRB 08 STI
Fav Mod: Only one - Cobb AP
Send a message via AIM to pwn
nice.
Driving a wrx, I never had the IC spray so I guess I won't care =]. One less fluid to keep in check.
pwn is offline   Reply With Quote
Old 12-11-2007, 02:50 PM   #8
^^ Tell me about it... I forgot to remove the water from the IC spray tank and it is now frozen. When I hit the brakes, the ice goes *clank, clank*. I hope the pump won't get destroyed...
Old 12-11-2007, 04:47 PM   #9
Car: << 07-STi >>
Fav Mod: A Good Wax Job
^^^ I Love my IC Spray.......(hit it at least 50 times a day) 50% alcohol 50% water. Works for me.
STIVendetta is offline   Reply With Quote
Old 12-11-2007, 04:50 PM   #10
Fav Mod: DOM3 Paperweight
Now that is not a bad idear.
Old 12-11-2007, 04:52 PM   #11
Worried about it freezing? You'd be better off with pure water, or just enough alcohol to keep it from freezing.
Old 12-11-2007, 04:56 PM   #12
^^ I am using pure water but no alcohol. I think alcohol will fade the STi letters off the IC over time.
Old 12-11-2007, 05:36 PM   #13
Car: << 07-STi >>
Agree^^....I can always repaint if necessary....alcohol prevents freezing and has a good cooling effect (evaporation) ...the alcohol "itself" is a 50% variety..not the 70-90-or 100% type. The smell is clean too!
Old 12-11-2007, 05:40 PM   #14
Alcohol will help with the freezing, but it will hurt the cooling affect, not help it.
Old 12-11-2007, 05:42 PM   #15
Car: << 07-STi >>
hmmmm...I was not aware of that.....Thanks!
