| | #251 | |
| STI Driver Feedback Score: 0 reviews Car: white 04 sti Fav Mod: s374 Location: mpls! Posts: 240
IWSTI Addict since: Dec 2005 | Quote:
this man is 100% correct! 700whp is still the goal and still plan on it. on this block and heads im shooting for in the 500s. but as for right now i cant get over 19psi due to 8 psi waste gate springs so im ordering stiffer ones. i also need to wire up that second walbro before i go any further. im thinking at 25psi and more that this car will just fly. so will keep updating | |
| | #252 |
| Spec C Club Feedback Score: 2 reviews | Glad to hear everything is moving along still. A project like this has to go one step at a time just like youre doing. I commend your patience through it all, I know its not easy. |
| | #253 |
| Professional STI Racer Feedback Score: 22 reviews | Any updates? :P |
| | #254 |
| S204 Racer Feedback Score: 1 reviews Car: 06 STi WRB Rally Car Fav Mod: Custom Rally Cage, intercom, roof scoop, cobra seats and hellaflush 15's Location: MASS-HOLE Posts: 3,197
IWSTI Addict since: Aug 2006 | he has a thread on NASIOC if you want to check it out. he's waiting for the built block to arrive I believe. he's still working out some leak issues with the exhaust and what not. I believe the prelim. numbers are the same seeing how he's still using the stock block. |
| | #255 | |
| Junior STI Driver Feedback Score: 0 reviews Car: 06 STI Fav Mod: KW coilovers and a 30R Location: You can find me in the A Posts: 155
IWSTI Addict since: Sep 2006 | Quote:
Good luck with youre project, we are tuning mine tommrow. | |
| | #256 |
| Spec C Club Feedback Score: 6 reviews Car: 04 Aspen White STi Fav Mod: exhaust powered intake Location: Charlotte/Winston Salem, Posts: 1,477
IWSTI Addict since: Jul 2006 | updates? |
| | #257 |
| Platinum Member Feedback Score: 3 reviews
Car: 07 STI SWP My Stuff: Subaru Parts Fav Mod: Custom built TBE FTW!!! Location: Modesto, California Posts: 1,200
IWSTI Addict since: Feb 2007 | Any new updates? |
| | #258 |
| IWSTI Club Level 1 Feedback Score: 5 reviews
Car: OBP-GDB cuh Fav Mod: realtime Location: Fullerton, Ca Posts: 14,016
IWSTI Addict since: Jan 2006 | +12345 |
| | #259 |
IWSTI Addict since: Dec 2005 | not much going on right now. i just took insurance off of it and am starting to do some work. its up on jack stands right now with the rear end out of it and am putting the 1000hp axles and hubs in as well as the alum drive shaft from drive shaft shop. after that it will be sitting for a while while i try to make some $$$ to put the bottom end together and get parts for the heads. |
| | #260 |
| Professional STI Driver Feedback Score: 7 reviews Car: 04 PSM STI Location: Denver, CO Posts: 410
IWSTI Addict since: Jun 2004 | Do you have the .035 oil restrictor pills on the oil feed line? That should keep the high oil pressure of the suby from seeping through the turbo seals. I have a .4bar small spring for a 44mm Tial wastegate if you need that to hold more boost. |
| Thread Tools | |
