Old 06-01-2006, 07:41 PM   #1
Car: '05 PSM
IWSTI Addict since: May 2006
Default High Coolant Temperature!?
I was just out driving around and stopped at a gas station after a while to fill the car when all of the sudden the ECUTek monitor started yelling at me. It was all " ALARM! High Coolant Temperature" so of course I checked the Coolant temp section and the monitor read around 202 degrees and the highest recorded is 212. Near the gas station I punched it one last time but before that I was being easy on her. What is the deal though? Any serious problems or am I just freakin' out?
I'm new to this website and the car so I'm not quite sure what is normal and what is not so don't get all angry like just help me out here please. I did a search right quick too but nothing too helpful came up.
KikBakKar is offline   Reply With Quote
Old 06-02-2006, 04:23 AM   #2
IWSTI Addict since: Aug 2005
Sounds like you need to change your alarm mark in the ECUtec... Those temps are not high by any means....
Old 06-02-2006, 06:32 AM   #3
Car: '04 WRB
Fav Mod: A working ECU...
IWSTI Addict since: May 2003
I'm usually around 197F coolant temp, pretty much the same...
Old 06-02-2006, 06:57 AM   #4
Fav Mod: 4th gear wheelspin
IWSTI Addict since: Nov 2004
The fan is supposed to come on at 207f, right?
Old 06-02-2006, 02:42 PM   #5
Car: '05 PSM
Ya, well I think I know what the problem was after all. Checked the coolant resevoir when the engine cooled and the level was quite a bit below the "Low" mark so i just filled her up to "Full". Thanks for not freakin' out on me though.
