Old 05-18-2006, 09:57 AM   #1
Car: 05 Subaru WRX STi
IWSTI Addict since: Jan 2005
Send a message via AIM to Bunghollio
Default hose question
what are th hoses that are connected to the TMIC? the metal one. can they be replaced with rubber hoses instead of metal?
Bunghollio is offline   Reply With Quote
Old 05-18-2006, 10:37 AM   #2
IWSTI Addict since: Aug 2005
I assume that you mean the "Y" pipe under the intercooler? No, it is a ridged piece for a reason. The hose that comes off of it can be replaced by many aftermarket versions so you can change colors....
Old 05-18-2006, 10:41 AM   #3
IWSTI Addict since: Sep 2004
The hoses that are connected to the TMIC are the breather lines for the valve covers. You can replace them with a rubber hose if you wanted to.
z71amigo is offline   Reply With Quote
Old 05-18-2006, 01:07 PM   #4
Muller Chevrolet
Fav Mod: beastly fenders
IWSTI Addict since: Oct 2004
yea you take off the stock, metal breather tube that bolts to the tmic..you simply replace with a new long hose and get a tee fitting for the left side.
Old 05-18-2006, 01:26 PM   #5
yea im talking about the black metal lines that are by the trottle body do i have to replace them with a FMIC setup? or i can make a custom bracket that holds it up?
Old 05-18-2006, 01:37 PM   #6
Car: 2004 Subaru WRX STi
Fav Mod: blasting you with the 44mm EWG!!!!!!
IWSTI Addict since: May 2006
Send a message via AIM to ImprezivSTi04
im pretty sure those crankcase breather lines can be replaced with rubber...since many aftermarket blow off valves send a rubber line to make room for the flange of the new bov...
ImprezivSTi04 is offline   Reply With Quote
Old 05-18-2006, 01:50 PM   #7
Muller Chevrolet
just replace it...the metal bracket and metal tube will just be in the way of the fmic piping.
