Old 05-13-2006, 05:15 AM   #16
Moderator & ECU Tech
Fav Mod: mo boostaz
IWSTI Addict since: Jun 2004
You don't need to ask your tuner about this one. The choice is easy. Nismo injectors. Period. They are easier to tune than the PE or Helix injectors ... and will give you a better idle. Moreover, they have more than enough headroom for a 20G install.
t
WolfPlayer is online now   Reply With Quote
Old 05-13-2006, 05:43 AM   #17
Car: 05 subaru wrx sti
Fav Mod: Ecutek Reflash
IWSTI Addict since: Apr 2006
dude go with the power enterprise injectors
evokillinSTi is offline   Reply With Quote
Old 05-13-2006, 06:51 AM   #18
Car: 05 Subaru WRX STi
Fav Mod: METH
IWSTI Addict since: Jul 2005
I have had hell with PE injectors I just recieved a replacement set because the ones i purchased new werent flowing right, after i put the other set in maybe i will change my views on PE but right now im not impressed. If i continue to have issues then I will be going to Nismo
CbnSTi is offline   Reply With Quote
Old 05-13-2006, 06:53 AM   #19
GT R US
IWSTI Addict since: Dec 2003
sure he does; unless youre his tuner.
Old 05-13-2006, 07:29 AM   #20
Fav Mod: METH
True True!
Old 05-13-2006, 08:57 AM   #21
Fav Mod: 4th gear wheelspin
IWSTI Addict since: Nov 2004
How did you discover they weren't flowing right?
jays05 is online now   Reply With Quote
Old 05-13-2006, 09:45 AM   #22
Fav Mod: METH
Well my tuner {scott siegel} and i diagnosed the idle, cel misfire codes, the choppiness of the power delivery, and the egt temps to the injectors. Also flow tested. Its been quite the headache because im so anal about my car , i will let u guys know what the outcome is.
Scott says he has had recent issues with guys with the pe 850"s so i dunno.....
Old 05-13-2006, 12:52 PM   #23
Car: Your STi ;)
Fav Mod: Everything
IWSTI Addict since: Mar 2005
On CBN's car the EGT sensor was showing VERY high EGT at idle and cruise. It dropped at WOT... When that injector was switched to another position the EGTs dropped (now being under a different injector). That seems to point to one injector being a bit "light."
For a long time the PE's have been SUPER consistent. We've had a few cars lately that seemed possibly have one injector that ran different than the others...
The Nismos have risen to the top for the moment as far as consistency...
SS
Old 05-13-2006, 01:03 PM   #24
Fav Mod: mo boostaz
This normally makes sense. However, as far as injectors for the STI are concerned, the Nismos are the best injectors available for the STI when you are going with a 20G install. Cobb agrees. Best in terms of quality. Best in terms of installation. Best in terms of idle characteristics. I could go on ... but I won't. If a tuner comes out and says the Helix or PE injectors are a better choice than the Nismos for a 20G install then I would doubt the knowledge and integrity of the Tuner.
Here is a comparison of the stock injector vs. the Helix. Yick. Helix has double o-rings, it is shorter, feels less solid, and you must use new retaining clips.
http://www.bescaredracing.com/sti/fu...elix/vs_stock/
In contrast, the Nismos are almost identical to stock.
The Nismos are easier to tune too (considering the end result when all is said and done).
t
Old 05-13-2006, 01:13 PM   #25
Fav Mod: METH
Looks like i might just be getting those nismo's......lets see what happens and since ive heard so many good things about the nismo's if the PE injectors dont work out i def feel like if i go with nismo i would be a happy camper..
thanks wolfplayer for the info
Old 05-13-2006, 02:35 PM   #26
Car: 2005 White/Gold STi
Fav Mod: TD06-20G/Tein Flex coilovers
IWSTI Addict since: May 2005
Some really good info here
So who sells the Nismo injectors?
pt518sti is offline   Reply With Quote
Old 05-13-2006, 02:54 PM   #27
nulla poena sine lege
Car: '08 GT500
IWSTI Addict since: Nov 2003
There is lots of info on modified injectors. From what I read, I would go the PE or Helix route or SARD. StaticXmotorsports has the SARD 850's.
QuickSilverSTi is offline   Reply With Quote
Old 05-13-2006, 03:07 PM   #28
A.X.D.
Car: 2004 STi
IWSTI Addict since: Apr 2004
+1
(going 20g )
Old 05-13-2006, 03:09 PM   #29
I'm having a hard time finding the "Nismo" injectors...
Are they sold under the name "Jecs"?
Also, are they just plug & play or do you have to modify anything?
Whats the average price for these anyway?
Old 05-13-2006, 03:11 PM   #30
A.X.D.
Car: 2004 STi
a quick search just now via Google showed me that they are going to be around $500 for the full set... most of the sites i looked at are actually in Japan.
(shipping costs and time may be a problem )
