Old 05-05-2006, 11:05 AM   #1
Car: 2005 Subaru WRX STi
IWSTI Addict since: Feb 2005
Send a message via AIM to Mochenmat
Default oil cooler
...ok i know what it does but what are the benifits of it...any downsides...
Mochenmat is offline   Reply With Quote
Old 05-05-2006, 11:24 AM   #2
Poor Speed Racer
Car: 96 328
IWSTI Addict since: Mar 2005
price. you will need a thermostat so that you are only using the cooler when you need it.
Old 05-05-2006, 11:29 AM   #3
Car: Blue 2004 STi
Fav Mod: 2001 2.5RS Rally car...
IWSTI Addict since: Apr 2003
oil below 190* does not function optimally. I can't back up exactly why but many sources cite this as the optimal temp for oil. Thus the need for thermostats if you live in a colder area.
Old 05-05-2006, 11:35 AM   #4
Car: '04 STi
Fav Mod: roof vent
IWSTI Addict since: Apr 2006
you might also have problems with oil changes if you don't do them yourself.
inchoate is offline   Reply With Quote
Old 05-05-2006, 11:37 AM   #5
STI Master
Fav Mod: Whooshing sounds
IWSTI Addict since: Nov 2003
The STi comes with an engine oil cooler and a transmission oil cooler from the factory.
05's even added a steering oil cooler.
No need to add these, you already have em.
Old 05-05-2006, 01:44 PM   #6
Poor Speed Racer
Car: 96 328
IIRC from the factory its not an oil cooler, but rather a heat exchanger. But i have been told by a LOT of people that our cars do not need them. I know a few people running T2 cars, and NONE of them have oil coolers.
Old 05-05-2006, 02:07 PM   #7
Car: 2004 STi
IWSTI Addict since: Feb 2004
The metal block we screw our oil filters into is pumped with coolant. It works well enough for most driving, but on the track I have seen the coolant slowly lose the battle.
daemon is online now   Reply With Quote
Old 05-05-2006, 02:23 PM   #8
Car: 05 Subaru STI
IWSTI Addict since: Oct 2005
Upgrade the radiator first. Becuase when you do that you actually are in a way upgrading your oilcooler also, since your oil cools from the heat exchange method as mentioned above.
BHRSTI is offline   Reply With Quote
Old 05-05-2006, 02:29 PM   #9
so this a useless mod unless you use her on the track alot
Old 05-05-2006, 02:39 PM   #10
Car: 05 Subaru STI
Depending on how you look at it. An oil cooler is always a good safety percaution. But you might as well use the money on a something else that will be more useful.
