| Professional STI Driver | I tried searching for the info I need but could not find it. I recently had a catted Helix DP installed to my stock catback and my installer said that I would get a small exhaust leak but I would not lose any power. I know that I am getting an exahust leak because when I warm up my car in the morning, water drips on the floor where the DP and CB meet. I also hear a weird noise when driving sometimes. Is there a way to fix this? I don't want to get an aftermarket CB right now. Should I even be concerned? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| S204 Racer | There's a leak because the DP uses a flat flange and the OEM cat back uses a donut flange. They are not 100% compatible. To be sure of completely stopping the leak, get an after market exhaust with a flat flange to mate up, have a flat flange welded on the OEM cat back, or go back to the stock DP. |
| | #5 |
| Professional STI Racer Car: 05 PSM STi w/ custom Fav Mod: TiaL 38mm vented free as a bird. Location: Maine Posts: 622
IWSTI Addict since: Mar 2005 Trader Rating: (1) | get a donut gasket or use hi-temp RTV and gob it on the flange, and tighten it. I would use an impact to make sure its tight. |
| | #6 | |
Where do I get this donut gasket and hi-temp RTV? | |
| | #7 |
| How YOU Doin? Car: 2006 Audi S4 Fav Mod: OMGHI2U! Location: Philly 'burbs Posts: 7,710
IWSTI Addict since: Apr 2004 Trader Rating: (8) | I don't think the donut gasket will help because there's nothing to hold it on to the DP. The stock DP to catback connection uses spring bolts and that donut gasket. It's kind of like a ball and socket connection. The donut gasket is held onto the downpipe by a little lip. That lip is what's missing from the Helix flange. I dunno, I guess you could cram one in there but what I'm trying to say is that there's no bolts to hold in the gasket like the normal flange gaskets. I guess that's what the RTV is for? |
| | #8 |
| Professional STI Driver Car: 04 STI Fav Mod: Koni shocks Location: BFE Iowa Posts: 494
IWSTI Addict since: May 2004 Trader Rating: (1) | This was my reservation with the helix, the only way to make fit is get a midpipe like the madad where it will have the flat flange on it then go through a flex joint then gradually taper back to 2.5" to mate up with your axle back. You then have a 'stealthback' peiced together. That flat flanged connection will not work with the stock mid pipe no matter what you do. |
| | #9 |
IWSTI Addict since: Mar 2005 Trader Rating: (1) | well on one side the stock side the donut will seal. On the other side with the flat flange I would use RTV. You can get it napa. I used the gasket with my catback and it had a flat flange and I had no problems. Now I have a full TBE so I just have RTV to seal it. I have driven the car and have no problems with leaks. |
| | #11 | |
| | #12 |
| Junior STI Driver Car: 05 Subaru WRX STi Fav Mod: Rally Armor! Location: Boone, NC Posts: 166
IWSTI Addict since: May 2003 Trader Rating: (0) | I had the same setup on my old WRX for 20k miles. No leaks. Did you use regular bolts, or reuse the spring bolts? You HAVE to use regular bolts to get a tight seal. What kind of gasket did you use? I used the ones provided by GRUPPE-S with the Helix downpipe. If you reused the stock gasket, try a new one. Helix has changed versions of their DPs so much I'm not sure where you have mount points, but on mine there was a mid-mount flange on the DP. The hole was oval and allowed for some adjustment. The proper mounting procedure for this type of DP is to hang it in place, install all DP -> Turbo bolts and torque (for a good seal), connect DP -> catback, and adjust mid-mount so that the flat plate of the DP is as flat as possible to the catback and torque the DP -> catback bolts. VV |
| | #14 | |
| | #15 |
| Platinum Member Car: 2005 & 2008 STI Fav Mod: Scott Siegel Tuning!!! :D Location: Columbus, GA Posts: 2,020
IWSTI Addict since: Mar 2005 Trader Rating: (11) | If all else fails, get a flex pipe and a flat 2-bolt flange and have it welded on to you CB in place of the stock flange. That would be the best and most reliable fix. This ad is not endorsed by this member. Please register or login to hide this ad. |
