Old 02-15-2006, 09:47 PM   #1
Car: 06 STi
Fav Mod: boost creep!!!!!
IWSTI Addict since: Dec 2005
Default Do I need Catch can?
My mods in my signature...Just want to buy it because it is cheap. I am looking for greddy one. Is it worth it? Hard to install?
Thanks
sti-06 is offline   Reply With Quote
Old 02-16-2006, 12:02 AM   #2
Car: 06 STi
anyone??
Old 02-16-2006, 12:10 AM   #3
Fav Mod: Protune
IWSTI Addict since: Jan 2005
i too would like to know.
ejbpnoy is offline   Reply With Quote
Old 02-16-2006, 12:28 AM   #4
Fav Mod: Perrin 30r Kit
IWSTI Addict since: Apr 2005
i dont think its really necessary, but it definitly wouldnt hurt to have one.
Old 02-16-2006, 07:19 AM   #5
IWSTI Addict since: Aug 2005
most stock "snails" dont requrie that you have one. Most I have seen with stock turbos never have anything in the cans, even with media in them. If you ever upgrade to bigger turbo with higher boost you will absolutely need one. My catch can when I had my VF39 never had a drop in it. When I switched to my setup now, there is a minimal amount that accumulates in the can. They key is to put some media in the can that the oil particles can stick too....
Old 02-16-2006, 08:18 AM   #6
Fav Mod: JDM Pink Struts
IWSTI Addict since: Jul 2005
Send a message via AIM to Allen504tke
No one needs any of their mods, they just like to have them. So no one is going to give you a 'Hell Yea' on a catch can
A catch can keeps the engine bay cleaner from blow-by oil. IMO I wanted one so my engine bay stayed cleaner than usual. Install is not hard at all.
-A
Allen504tke is offline   Reply With Quote
Old 02-16-2006, 01:00 PM   #7
IWSTI Addict since: Oct 2004
catch can = 50whp...no but im going to invest in one after my turbo upgrade...lol
White05sti is offline   Reply With Quote
Old 02-16-2006, 01:06 PM   #8
Fav Mod: FYI, I'm a dude
IWSTI Addict since: Mar 2005
-A
+1 i just bought a greddy one from a member here. i'm still on the vf39, so i know it probably won't do much, but it sure is purty! bling ftw!
Old 02-16-2006, 01:29 PM   #9
Moderator & ECU Tech
Fav Mod: mo boostaz
IWSTI Addict since: Jun 2004
Oil seriously lowers the octane of gas. Get oil into your intake ... enough of it ... and be rewarded with inconsistent performance due to pulled timing.
t
Old 02-16-2006, 02:51 PM   #10
IWSTI Addict since: Apr 2004
It has zip to do with keeping the engine bay "clean." The breather lines don't vent to the engine bay - they vent to the intake.
The purpose of catch cans is twofold: 1, they trap blow-by liquids that would otherwise get into the intake which, as Wolfplayer already stated, reduces the octane of the intake charge; 2, they act as an "early warning system" for your lower end. IOW, if they fill up all the time you've got a motor with bad blow-by that is on its way out.
Others are correct in that you probably don't need one at all with the stock turbo, but if you go "big", you'll want one - preferably two.
Flycaster is online now   Reply With Quote
Old 02-16-2006, 02:59 PM   #11
Car: 06 White STi
IWSTI Addict since: Nov 2005
Send a message via AIM to The White Pony
Hey it wouldnt hurt to add a little bling now would it!?
The White Pony is offline   Reply With Quote
Old 02-16-2006, 03:15 PM   #12
Far be it from me to argue against bling!
Old 02-16-2006, 04:08 PM   #13
Titanium Member
Fav Mod: Bill
I've heard running the snot out of your STi (even with the stock snail) can cause blowby oil to the intake which can first show up in the TMIC. If you pull your TMIC and there is oil then maybe a catch can is for you......Please correct me if I'm wrong.....
Here's a link for DIY....
http://www.pbase.com/rsrock/oil_catch_can
I've seen other versions with fuel filters with paper elements in them.....
Old 02-16-2006, 04:50 PM   #14
Nope, you're right. Anytime you have oil in the pipes, you want a catch-can.
Old 02-17-2006, 12:33 PM   #15
Car: 2006 STi
Fav Mod: power adding stickers & emblems
IWSTI Addict since: Aug 2004
when I removed my stock TMIC to do my oil pressure gauge, I set the IC in a cardboard box for a couple days, outlet down. When I went to reinstall it there was a little oil in the cardboard box that had run out of the IC. This was within the first 3000 miles on my odo, so the engine is still far from fully broken in, but I want to add a catch can just to keep the IC clean.
Wazazell is offline   Reply With Quote
