| | #16 |
| Amateur STI Driver Car: 04 WRX STi Fav Mod: ACPT Carbon Fiber Driveshaft Location: Edgmont, PA Posts: 8
IWSTI Addict since: Apr 2005 Trader Rating: (0) | I am going to try using a bildge pump and putting it ionto the trunk's resevoir while the vehicle is parked on a hill. I will let you guys know how that works. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #18 | |
| Professional STI Racer Car: 05 WRX STi Fav Mod: Rare USDM SUBARU letters on trunk Location: Autozone Posts: 642
IWSTI Addict since: Oct 2004 Trader Rating: (0) | Quote:
But you are correct...give Gumpa a warning. | |
| | #19 |
IWSTI Addict since: Apr 2005 Trader Rating: (0) | I actually found that the best method for draining the tank is just by purchasing a simple NEW not used Kerosene Pump. It's cheap, $3.00, and it easily drains the entire tank of water. Just stick the tube into the deepest part of the resevoir and pump the water out. Beats pushing the button all day. |
| | #21 |
| dances with roads | *sigh* I can't believe I actually had to move a 2 year old thread... |
| | #22 |
| Professional STI Racer Car: 04 WRB/ GOLD STI Fav Mod: snail sticker = 5hp Location: Raymore, MO Posts: 792
IWSTI Addict since: Feb 2003 Trader Rating: (0) | It takes 8 minutes to drain a completely full tank. I have been thru two winters of daily freeze/ thaw cycle we get in the midwest. No problems. Distilled water only. |
| | #24 |
| Junior STI Driver | If you leave the resevoir empty the "i/c water spray" light will stay on. That light drives me crazy when it is on(esp. when the tank is getting low & it "flashes" as I drive). I would just leave it half full as Subaru suggests or put a little rubbing alcohol in it. |
| | #25 |
| Amateur STI Driver | Fellows, My IC bottle is freaking frozen solid! Do you guy put any sort of salt, anti-freeze, alcohol.... in yours for the winter? Wonder if anything will be damaged. |
| | #26 |
| Junior STI Driver | I emptied mine, but the IC light stayed lit. I put in a mixture of water, windshield wash and alcohol. It's about 1/4 full. I will just siphon it out after the cold weather leaves us. |
| | #27 |
| Senior STI Driver Car: Was: 05 Aspen White Location: Spokane, WA Posts: 335
IWSTI Addict since: Jan 2005 Trader Rating: (0) | The search button is your friend, as is your owners manual. Intercooler Water Spray Freezing Water Spray Frozen? i/c water spray tank |
| | #29 | |
| DirtyImpreza.com Car: 04 STi, 01 RS Fav Mod: ACPT CFDS Location: Southern California Posts: 674
IWSTI Addict since: Dec 2004 Trader Rating: (3) | wow, this IS an old thread. But if anyone is looking for the info.. use this to pump out the water: ![]() Quote:
| | #30 |
| Moderator Elite
Car: 2005 Subaru WRX STi Fav Mod: Underglows Location: Tyler, Texas Posts: 8,939
IWSTI Addict since: Jul 2005 Trader Rating: (0) | And the water freezing is fine as long as you don't have it too full, and like the previous poster said, don't hit the I/C button, you don't want to burn out the pump. If it's cold enough to freeze the water in your I/C spray tank then you don't even need to worry about spraying your I/C, cause the cold air will be good enough. This ad is not endorsed by this member. Please register or login to hide this ad. |
