Old 11-25-2005, 08:59 PM   #1
Car: 01 Subaru WRX STi Spec C
IWSTI Addict since: Jun 2005
Default Downpipe install.
HI there,
Good news.....I will be finally installing the Catted Helix tom.
Anything that I have to know before? Any detail that I need to pay more attention to?
I will be doing this alone. I am expecting 4-5 hours to finish the job.
Is there like a general guideline for installing the dp, I don't wanna mess anything up.
EDIT: one more thing...is wrapping of the dp recommended, too??
TAHNSK!!!!!!
any input WILL BE appreciated.
SilverSTi2004 is offline   Reply With Quote
Old 11-25-2005, 09:28 PM   #2
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
breaker bar, and pb blaster for the bolts and studs on the turbo. besides that, some patience.
Old 11-25-2005, 09:35 PM   #3
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
IWSTI Addict since: Aug 2005
Trader Rating: (78)
Alone??
Def breaker bar.... beer...patience....and more beer...
i suggest you have a helping hand, those bolts are ****ing stubborn as hell..
if you need help just PM me...did this twice already on my sti and my buddies.
Old 11-25-2005, 09:41 PM   #4
Fav Mod: Perrin 30r Kit
IWSTI Addict since: Apr 2005
just be sure to soak down the bolts and you shouldnt have a problem getting them off. just make sure you loosen them slowly so you dont mess up the threads (like i did). its easy.
Old 11-25-2005, 10:04 PM   #5
Car: 02 Aspen White WRX
Fav Mod: wrx-->sti
IWSTI Addict since: May 2005
Send a message via AIM to Swine
Yeah, just a good coat of some PB and tap the bolts that you spray with a wrench or something so the pb sinks in better. Other then that it is fairly straight forward. You really cant mess anything up that cant be somewhat easily fixed. The only thing you might have a problem is exhaust leeks...which is not a serious problem. Just have patience, and be prepared for everything to not go smoothly...it never does the first time.
Swine is offline   Reply With Quote
Old 11-26-2005, 06:31 PM   #6
Alright.
Didn't get it installed yet. Too cold today. and got up so late. Hopefully tom. Picked up a 2.5 ton jack + 2 stands today.
Thanks for all the inputs.
Do you guys know anything about the heat shield and the dp wraps??
I heard that the heat shield, you can cut up the stock one. How much of it do I have to cut? and the dp wrap...I saw that xstatics is selling the wrap for like $45 or something. Is the wrapping recommended for an aftermarket dp?
thanks again
Old 11-26-2005, 07:08 PM   #7
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
Trader Rating: (78)
pick up an o2 socket...and maybe you should have bought ramps? i know its tight under there with just the front up, you might want to put up the rear as well...
If you want to wrap your DP and plan to put it in tmrw....dont put it in, wait till you get the wrap stuff...
And i just went with a cusco heatshield, but some even cut the stock one...wrapping is controversial...but it sure will lower the heat coming off the pipe...
Old 11-26-2005, 07:52 PM   #8
Do the jack stands lift the car high enough (I got the craftman 2.5 ton stands)? If so, I can just get another set from my friend.
you guys are the best! :P
Old 11-26-2005, 08:17 PM   #9
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
Trader Rating: (78)
they can lift the car as high as you want, but i rather have it level for safety reasons, and the higher you bring up the front..the lower the back gets..
Plus i have trouble jacking the front only up due to the thin jack point, they bend and ****... what i do is drive up on stands, and jack the rear by the rear diff, and then put in 2 stands...
Old 11-26-2005, 09:33 PM   #10
Fav Mod: High tensile moon noodles
Send a message via AIM to Puckshaw Send a message via Yahoo to Puckshaw
Well I just did the install today. A few pointers:
Have a breaker bar handy as mentioned
Gear wrenches are a life saver for a lot of those bolts
Socket extensions come in handy too
Drown everything in PB Blaster
Just cut the stock heat shield
Remove the intercooler (not very hard to do and frees up a lot of room)
Have an extra set of hands
Take your time
It's time consuming but not too bad. You're gonna love the dp. I got the same one.
Nate
Puckshaw is offline   Reply With Quote
Old 11-26-2005, 09:36 PM   #11
Same thing happened to me. I messed up the sideskirt
I wish I have a lift
Old 11-26-2005, 09:49 PM   #12
You can jack up the car in the front center and put it on jackstands.
Nate
Old 11-26-2005, 09:49 PM   #13
Fav Mod: wrx-->sti
No need to remove the intercooler. I have done several dp installs without removing the i/c. It has never been in the way or caused a problem. The three bottom bolts on the dp will be easier accessed from the bottom. Heads up.
Old 11-26-2005, 09:52 PM   #14
True it's not required to remove it but it doesn't take hardly any time and makes for a much easier install. Just my opinion. Plus I just like getting in there and taking stuff apart. It's the best way to learn about my car.
Nate
Old 11-26-2005, 10:11 PM   #15
Nate
Nate, how long did it take you? I'm expecting 4 hours alone, with PB blasters.
