Old 11-24-2005, 11:36 AM   #1
JSK
Car: White 2004 STi
IWSTI Addict since: Mar 2005
Default Estimated time of installing these items
Needing some opinions please.
I'm getting ready to pay a shop to install the following items. Can anyone give me some estimates on what the install time should be around for each item - I just want to make sure I'm not going to get ripped.
Deadbolt 20G
Perrin FMIC
PE 850 Injectors
Walbro Fuel Pump
Lightweight Crank Pulley
1 step colder plugs
zeitronix gauge set (EGT,AFR,,Boost)
Cobb F/R Sway Bars
As you can see I have been saving up parts for one big install/Tuning.
Any input would be greatly appreciated!
JSK is offline   Reply With Quote
Old 11-24-2005, 02:29 PM   #2
IWSTI Addict since: Apr 2004
Looking at you list, the FMIC is the big variable. Someone who's done a couple of these before can probably whack one out in a couple of hours, but a newbie might take 5 or 6. There is cutting involved, none of it fits totally perfectly, and there are ZERO directions.
Most tuner shops want the car for at least a full day for a complete turbo system upgrade and a FMIC install. I dunno...you're probably looking at 12 hours labor to get it all done right, maybe a bit more. If you could find a shop that has done all this before and would charge you a single day's labor as a "package deal" to do all of it at once, you've got a great deal, imo.
Flycaster is online now   Reply With Quote
Old 11-24-2005, 09:45 PM   #3
Fav Mod: sleeved ej257 + GT35R
IWSTI Addict since: Jun 2004
Originally Posted by JSK
Deadbolt 20G <---with the TMIC already off I'd venture to say about an hour
Perrin FMIC <---4-5 hours done by a shop
PE 850 Injectors <---about an hour
Walbro Fuel Pump <---about 45 minutes to an hour
1 step colder plugs <---most guys can swap these in 20 minutes
zeitronix gauge set (EGT,AFR,,Boost) <---a little difficult to estimate...does your downpipe have a bung for the o2 sensor? is your header already tapped for an EGT gauge? I'd say up to 4
I would get quotes for how many hours they think they will take on the big stuff and compare it...I've been screwed hardcore on labor before because I didn't heed the advice I'm giving you.
sachin is offline   Reply With Quote
Old 11-24-2005, 09:54 PM   #4
JSK
Car: White 2004 STi
Thanks guys. I guess anything less then 12 hours would seem to be reasonable. There are a lot of big things am asking to be done.
Old 11-27-2005, 10:09 PM   #5
Car: G35 & GS350 & JAZZ
Fav Mod: Turbo upgrade
IWSTI Addict since: Jul 2004
Send a message via AIM to stibaby Send a message via MSN to stibaby Send a message via Yahoo to stibaby
Topspeed quotes me that take them 3 hour for turbo $70 an hour and 3 hour for SMC Kit
stibaby is offline   Reply With Quote
