Old 11-16-2005, 07:23 PM   #1
Car: 06 AW STI
Fav Mod: WRX trunk
IWSTI Addict since: Nov 2005
Default Need some feedback on my STi project.
ENGINE/POWER
□ K&N wrinkle red Typhoon intake- $210 (cardomain.com)
□ Cobb Tuning Stage2 power package w/cat- $1775 (cobbtuning.com)
□ HKS Circle Earth ground wires- $130 (scoobytuner.com)
□ STi radiator cap- $50 (scoobytuner.com)
□ APS SR55 turbo- $2096 (scoobytuner.com)
□ APS TMIC BOV- $260 (scoobytuner.com)
□ APS TMIC- $890 (scoobytuner.com)
TOTAL: $5411
TRANSMISSION
□ STi short shifter- $390 (scoobytuner.com)
□ STi stainless steel clutch line- $95 (scoobytuner.com)
□ STi 7.7mm organic clutch disc- $370 (subaru.com/microsites/spt)
□ STi 7.7mm clutch cover- $430 (subaru.com/microsites/spt)
TOTAL: $1285
SUSPENSION/CHASSIS
□ KartBoy rear differential bushing kit- $32 (subaruwrx.com)
□ Whiteline steering rack bushings- $30 (subaruwrx.com)
□ STi pink springs- $299 (fastwrx.com)
□ STi front upper mounts- $110 (gruppe-s.com)
□ STi rear upper mounts- $185 (gruppe-s.com)
□ STi rear link set- $350 (gruppe-s.com)
□ STi trailing arm set- $275 (gruppe-s.com)
□ STi lower arm bar- $239 (boomplustoys.net)
TOTAL: $1520
BRAKES
□ SS brake lines- $145 (cobbtuning.com)
TOTAL: $145
WHEELS/TIRES
□ ADR 18X7.5 silver Sokudo 10- $199ea. ($796) (thewheelconnection.com)
□ Bridgestone 235/40YR18 S-03 PP- $226 ($904) (tirerack.com)
TOTAL: $1700
TUNING/MANAGEMENT/FUEL
□ AutoMeter Sport Comp boost-vac 2 1/16" 20psi gauge- $55 (cardomain.com)
□ AutoMeter cluster bezel 20015- $70 (cardomain.com)
□ Walbro 255lph fuel pump- $100 (gruppe-s.com)
□ Power Enterprises 850cc injectors- $640 (scoobytuner.com)
TOTAL: $865
GRAND TOTAL: $10926+s/h, tax, labor, dyno tuning
Nothing TOO serious.
I just want some (or A LOT) of feedback on my approach this being my first turbo car. And it would also be cool if anyone knows where I can get better prices than the ones that I have found. Or if anyone is looking for low prices and this helps then great.
Oh yeah, I also want to retain stock boost (or as close as possible with the COBB AP Protuned (thinking about HarmonMotive, heard great things, only it's about 6 hours away. More time to enjoy my car there and back though I suppose. )
Thanks. GREAT SITE!!! Very helpful people and haven't seen any dip$**ts that mess everything up for everyone...yet.
Here's my new list...tell me what you guys think. Is it better than my previous? Also, does anyone whether or not I will need a new turbo inlet pipe with the SZ55? Thanks!
ENGINE/POWER
K&N Typhoon intake- $210 (cardomain.com)
Cobb Tuning 04 STi Stage 2 power package w/cat- $1775 (cobbtuning.com)
Deadbolt Fatboy SZ55 turbo w/int wastegate- $1995 (boostplanet.com/product7.htm)
Nismo 740cc injectors (set of 4)- $550 (gruppe-s.com)
some kind of TMIC (?)
Sun Automobile Hyper Ground wires S-Type (smoke)- $110 (prolightstar.com)
STi radiator cap- $50 (gruppe-s.com)
TOTAL: $4840
TRANSMISSION
ACT HD Street Disc kit- $550 (gruppe-s.com)
TOTAL: $645
SUSPENSION/CHASSIS
TOTAL: $656
BRAKES
TOTAL: $145
TUNING/MANAGEMENT
AutoMeter Sport Comp boost-vac 2 1/16" 30psi gauge- $55 (cardomain.com)
TOTAL: $125
GRAND TOTAL: $6411+s/h, tax, labor, dyno tuning
dsupermansti is offline   Reply With Quote
Old 11-16-2005, 07:36 PM   #2
IWSTI Addict since: Apr 2004
First, you have to figure out what you want to accomplish.
Then, do yourself a favor by researching tuners. Start here:http://www.iwsti.com/forums/forumdisplay.php?f=137 Settle on one, call 'em up, tell 'em what your goals are, and let them put together an entire package (including installation) for you. You have a lot of parts here, some of which do not work together, some of which you don't need, as well as others that are missing, and a tuner will be able to guide you through the whole complex process, not to mention save you quite a bit of money from the looks of what you want to accomplish.
In order: goals first, tuner second, parts third.
Old 11-16-2005, 07:47 PM   #3
Car: 06 AW STI
Fav Mod: WRX trunk
Thanks, but would you mind telling me what parts won't work together? I REALLY do not want to mess this up, but I have also dealt with shady dealers/tuners in the past and that's my reason for asking on this site. No bias and no need to "sell". Thanks again. I'll try that link.
Old 11-16-2005, 08:44 PM   #4
Car: 996TT
IWSTI Addict since: Jul 2004
Trader Rating: (12)
Send a message via ICQ to esemes Send a message via AIM to esemes Send a message via Yahoo to esemes
youll NEVER get the performance from the TMIC that the sr55 needs....
no way the timing will be able to be agressive enough....
ese
source: APS, peter, david: MASTRO (personal flops)
NTM, APS states their TMIC is NOT designed or rated for the usdm STI.....
now, will it work with a smaller (better?) turbo?
ese
ps- define as per flycaster first; avoid costly lists like this - they lead to alot of heartache, bro..
esemes is offline   Reply With Quote
Old 11-16-2005, 09:44 PM   #5
Car: '08 335xi Coupe
Fav Mod: Dinan Reflash
IWSTI Addict since: Aug 2005
Ya, +1 to all the aboce. If you are looking to go beyond your typical cobb stage 1 and stage 2 set ups then get yourself to a dedicates tuner with experience tuning subies. A tuner will know the best ways to spend your money and will have the experience to put it together right so that you do not blow up your baby. Take it from a guy who blew up a small block v-8, you dont want to do this wrong.
Old 11-20-2005, 10:17 PM   #6
IWSTI Addict since: Jan 2005
i would seriously follow advice of ese and others... please read the boards.. if you want to go EXTREME setup.. talk to bruce, if you want to go basic turbo upgrade, talk to half of the board... read read read.. that is the only way to learn.
AdamBlitzer is offline   Reply With Quote
Old 11-20-2005, 10:38 PM   #7
Car: 04 STI & 05 EVO MR
Fav Mod: APSTSR70 :D
We would recommend a FMIC (rated@500+hp) with the SR55. If you don't mind me asking; what are the climates at your location.
Your wheel choice seem to be narrower than stock wheels (7.5 vs. stock's 8) any reason for this. We would recommend stay at the stock 8in or go to a 8.5 inch.
Also just so you know that the STi short throw shifter assembly reduces the shifter gate travel by a good amount (I don't have the exact figure in front of me right now); however, the actual shifter will not sit much lower than stock if you are going for the small shifter look. You may want to also consider a kartboy short shifter as well. I personally have the STi short shift kit along with the kartboy shifter/bushings; and I like this combo.
Best of luck.
MZM Performance is offline   Reply With Quote
Old 11-21-2005, 09:05 AM   #8
Car: 06 AW STI
Fav Mod: WRX trunk
Best of luck.
Well, I'm about 45min north of Sacramento so whatever the climate is here, i'm not too sure. I've heard that the FMIC is good if you are going for 450-500hp/whp (not sure), but that the TMIC would be okay for maybe up to 400. I live in California and I'm not sure if changing to a FMIC will be legal because it's too obvious. I figured that a TMIC would be a little more low key and not too obvious that it isn't stock just by looking at it. oh and I've decided to go with a Deadbolt SZ55. I did some research and wound up at Harman Motive's site. The SZ55 seems to make more hp at a lower psi than the SR55. I'm not trying to go too crazy with it but I would like up to 360-380whp.
About the wheels; I have an 04 and i read somewhere on here that the stock wheels on the 04's are 17x7.5 and the 05's are 17x8. Any validity on that? I would love to go 18x8 with maybe some 235/40-18 tires.
I was hoping for that response for the STi short shifter with the Kartboy and WHiteline bushings.
Thanks again everyone.
Old 11-21-2005, 09:07 AM   #9
Car: 06 AW STI
Fav Mod: WRX trunk
Yes, I have done A LOT of reading lately on this site. A LOT of useful info. My list has changed somewhat now. Well, mainly the turbo (DB SZ55 instead of APS SR55). Thanks for your advise though.
Old 11-21-2005, 09:10 AM   #10
Car: 06 AW STI
Fav Mod: WRX trunk
ese
ese
It doesn't fit?! Damn- thanks for the info! I still would like to go with a TMIC though. I've been waiting for the Cobb TMIC to come out. Maybe even the ESX one. I'm gonna make sure on fitment now though. Thanks again!
Old 11-21-2005, 09:19 AM   #11
Car: 06 AW STI
Fav Mod: WRX trunk
I hear ya! Used to be into those lil' Hondas that make a bout 3-10hp for $200-$1000+. Plus they could never get the power to the ground so it was all just a waste of money for my purpose for it which was just a fast street car. Kinda hard to go fast when you're just smoking tires all the way through 3rd gear. Wasted too much money with Hondas. Gotten a lot wiser though that's why I joined, to gain knowledge from other people/tuners and get the appropriate approach. It's a lot more helpful here than at most (if not all) of the honda sites. Thanks again.
Old 11-21-2005, 09:36 AM   #12
Car: 996TT
Trader Rating: (12)
ESX- TMIC
been there, done that......
with the biggie SR55:::
closer:::
fitment was a BIG compromise; however.......
use caution:
ese
Old 11-21-2005, 07:01 PM   #13
Car: 06 AW STI
Fav Mod: WRX trunk
ESX- TMIC
closer:::
use caution:
ese
Big compromise? You didn't have to bang on anything to get it to fit did you? How well does the SR55 work for you as far as lag and top end? Damn, if only someone knew whether or not it is illegal to change to a front mount here in CA. Guess I'll just wait to see how the Cobb unit is (whenever THAT comes out). Thanks!
Old 11-21-2005, 10:40 PM   #14
Car: 04 WRX STI PSM
Fav Mod: PE1820 or Tein Flex's
IWSTI Addict since: Oct 2005
Send a message via AIM to st0k3d
do some research before dropping that much money on the SR55... you may find its performance doesnt suit your needs
st0k3d is offline   Reply With Quote
Old 11-22-2005, 05:03 AM   #15
GT R US
IWSTI Addict since: Dec 2003
i'd lose the sr55 and the top mount. if youre going to spend money on a clutch, do an act or rps. i don't see sways on your list. aside from the pinks you could lose the balance of sti parts from your suspension list and had hardened tops to it. let your tuner decide on injectors; some don't like pe's. good luck and be patient.
