Old 11-11-2005, 08:57 AM   #16
IWSTI Addict since: Mar 2004
From what I've read, though the GT35R makes more power, it is also difficult to keep the boost up between shifts, that is why it seems the FP Reds perform better at the track without the need for Nitrous to keep the turbo spooled.
GetterDragun is offline   Reply With Quote
Old 11-11-2005, 03:10 PM   #17
Car: 01 Subaru WRX STi Spec C
IWSTI Addict since: Aug 2005
Trader Rating: (14)
The GT35R is definitely a 10 second turbo for the STI. The response is actually better than the red due to the ball bearing design. A lot of the poor response between shifts that we are seeing is actually due to either a mismatch of components (turbo kit & head work) and/or a bit of improper tuning. Translated it often means that the turbo is sometimes larger than optimal for the car.
Cheers,
Gary
Gruppe-S
Gruppe-S is offline   Reply With Quote
Old 11-11-2005, 03:24 PM   #18
IWSTI Addict since: Mar 2005
the red is 10s capable as well tho isnt it
rob142sti is offline   Reply With Quote
Old 11-11-2005, 03:27 PM   #19
GT R US
IWSTI Addict since: Dec 2003
i'm not sure 500+ whp is going to do 10's.
Old 11-11-2005, 03:37 PM   #20
you dont think if the red was pushed to its limits that it would be able to break into the tens?? im talking about a built block and all supporting hardware?? all the reds done around are done on stock or close to stock block.. pdx got 5xx hp on the thiers with pistons at a low psi.. im wondering what kind of numbers the red would produce with more boost then what it has been tested at.. then again the gt35r would be better with the same mods.. but still for the price---
Old 11-11-2005, 03:48 PM   #21
IWSTI Addict since: Dec 2004
You still can't complain about the red.......look at its powerband, all the usable power!!!!!!!!! I know the GT35R is an amazing turbo.....look at the results. I am still amazed with my RED, and wouldn't go with a different setup. It all comes down to what kind of car you want. I don't drag race, so the red is the perfect street turbo.
mllrsti is offline   Reply With Quote
Old 11-11-2005, 04:00 PM   #22
i read of someone pushing the red to an 11.2 on nasioc with the stock block.. i really do believe 10's are capable
Old 11-11-2005, 04:02 PM   #23
Could be a possibility......I am sure we will find out if someone does it!
Old 11-11-2005, 04:03 PM   #24
GT R US
i'd rather be wrong, btw. it's a great turbo.
Old 11-11-2005, 05:22 PM   #25
Am I misbehaving? Please tell a moderator by clicking on the "report this post" button if I am. Thanks!
Car: 05 blu on silver
IWSTI Addict since: Jul 2005
a red doing 11.2 is amazing i think i want the big hit of the 35r tho.
ryanpietro is offline   Reply With Quote
Old 11-11-2005, 05:42 PM   #26
Send a message via AIM to UA_STI
Kind of sounds like you have your mind made up already.
UA_STI is offline   Reply With Quote
Old 11-11-2005, 05:52 PM   #27
so where are we finding the 35r for a good price??
Old 11-11-2005, 05:56 PM   #28
Trader Rating: (14)
On our dyno 500whp will run 10's... Easily I can't speak for other dynos as dyno number are all relative, I can say I have not seen many 500+whp cars being able to backup their dyno numbers with timeslips. As for running 10's with an FP Red, I think it will be exceptionally difficult given the stock chassis.
For the GT35R because of the size of this turbo, it is virtually impossible to mount it in the stock location, so you'll have to look for one of the rotated kits. Also if you're shooting for 10's, make sure you're getting at least a 44mm wastegate.
Cheers,
Gary
Gruppe-S
Old 11-11-2005, 07:01 PM   #29
look in our classified section. syoung has an awsome kit for super cheap.
