Old 11-10-2005, 08:20 AM   #1
Fav Mod: COBB Stage 1!
IWSTI Addict since: May 2003
Default Oil smells like gas
Hi All,
I've put about 2K miles on the car since the last oil change and the oil is dark and smells a little like gas. Is this a sign of a problem (as in- should I mention this to the dealer before my bumper-to-bumper warranty expires)? I've never noticed the gas smell before. Searches have yeilded little info.
Car is stock, BTW.
Thanks!
windmill is offline   Reply With Quote
Old 11-10-2005, 08:29 AM   #2
Car: 05 CGM STi
IWSTI Addict since: Jun 2005
It seems to be common with these cars because they run very rich-I checked my oil the other day and could smell the fuel on the dipstick.
solbergfan is offline   Reply With Quote
Old 11-10-2005, 08:37 AM   #3
IWSTI Addict since: Aug 2005
yep the richness causes this in our cars. Mine was the same way.
Old 11-10-2005, 08:41 AM   #4
Car: WRB 2004 WRX STi
IWSTI Addict since: Apr 2004
maybe 500 miles after an oil change,my oil always smells faintly of gas... i'm guessing you do much stop and go.
i drive 6 miles each way to and from work which seems to exacerbate the blow by problem.
i wouldn't worry about it.
g
gbonesti is offline   Reply With Quote
Old 11-10-2005, 09:04 AM   #5
IWSTI Addict since: Oct 2004
maybe this is normal for our cars but this is not right. This leads to heavy oil consumption and in my case a blown engine. Take it to the dealer!!!
Madness is offline   Reply With Quote
Old 11-10-2005, 10:38 AM   #6
Car: 1983 Mercedes Benz 3
IWSTI Addict since: Feb 2004
I did my first oil change at 1K miles, and it STUNK of gasoline!! Changed it every 3K miles since, and haven't burned a drop. Oh, it doesn't stink anymore.
Ol'SaltyBastard is offline   Reply With Quote
Old 11-10-2005, 10:44 AM   #7
Car: 07FXT. Fast
blowby
Your motor was new, so the rings were not sealed as well as they are/will be, which allows a lot of blowby past them.
Davenow is offline   Reply With Quote
Old 11-10-2005, 10:45 AM   #8
self healing? your lucky!
Old 11-10-2005, 11:01 AM   #9
Car: 07FXT. Fast
not self healing
The rings just seal better after the break in is done.
Old 11-10-2005, 11:19 AM   #10
Fav Mod: La Quarta Stella
IWSTI Addict since: Sep 2003
If you are paranoid, you can: 1. Get an oil analysis done by blackstone labs and 2. have a leakdown/compression test done on the motor.
Singletrack is offline   Reply With Quote
Old 11-10-2005, 08:00 PM   #11
GT R US
IWSTI Addict since: Dec 2003
3. take a lighter to your dipstick. if you can use it like a fire swallower you've got a problem.
Old 11-10-2005, 08:12 PM   #12
IWSTI Addict since: Mar 2005
They call this cylander wash.. When the gas from the chamber actually goes past the ring and into the oil pan... Be very weary of this as gas will reduce the effectivness of the oil.... This means you may not have a fully broken in motor...
Adam
Adam is offline   Reply With Quote
Old 11-11-2005, 07:10 AM   #13
Hahahahaha - nice.
Old 11-11-2005, 07:12 AM   #14
Adam
It could easily be a clearance issue also, i.e. there might just be too much room between the cylinder and the piston.
Old 11-11-2005, 11:18 AM   #15
What I understand from my engine builder is Subaru Turbo cars have always been known for this.
