Old 11-02-2005, 01:43 PM   #16
Car: 05 AW STi
IWSTI Addict since: Apr 2005
Send a message via AIM to STiLLsLow
Originally Posted by adidaSTi
Hey just wondering if anyone is using this with the oem oil temp sensor? Just want to make sure it will mate up fine beforei order one. Thanks
help...i really want one!
STiLLsLow is offline   Reply With Quote
Old 11-02-2005, 05:22 PM   #17
Car: Beater Van
IWSTI Addict since: Feb 2004
Have you guys use the supplied gasket, or the factory crush gasket (if thats what it's called)? I'd like to install mine tomorrow.
Hawaii_guy
Hawaii_guy is offline   Reply With Quote
Old 11-02-2005, 05:58 PM   #18
IWSTI Addict since: Apr 2004
OEM sensor replaces the stock bolt. Fumoto valve replaces the stock bolt. Guess it won't work.
MeoW71 is offline   Reply With Quote
Old 11-02-2005, 06:08 PM   #19
Muller Chevrolet
Fav Mod: beastly fenders
IWSTI Addict since: Oct 2004
the nipple version does not cause any clearance issues with anything
Old 11-02-2005, 07:35 PM   #20
IWSTI Addict since: Aug 2003
Hawaii_guy
I used the supplied gasket with no crush ring. Some people have installed it with both, others with just the crush washer, and others with just the supplied gasket. Make sure the Fumotovalve screws in smoothly. Some people have (apparently) screwed it in at a slight angle and cross-threaded it and have ended up with leaks. Once I tightened it by hand, I used a crescent wrench to go another 1/3-1/2 turn.
F4yoshi is offline   Reply With Quote
Old 11-02-2005, 08:25 PM   #21
Car: 05 AW STi
Damnit, guess i ll have to stick to the hard way. thanks
Old 11-02-2005, 08:43 PM   #22
Car: White 05 LGT Wagon
IWSTI Addict since: Aug 2004
Send a message via AIM to atc5
watch the gasket on these things...all said and done and after having one.....it's not that big of a deal to loosen the damn drain bolt and drain the oil
atc5 is offline   Reply With Quote
Old 11-02-2005, 09:21 PM   #23
Car: 2004 WRX-black
Fav Mod: COBB downpipe & Accessport
IWSTI Addict since: Aug 2005
i like my nippled valve because i don't have to wait for the oil to cool, i bought a rubber hose and I just drive up my ramps, connect the hose, then flip the switch and it drains into the pan. thats its main benefit in my opinion.
arsonall is offline   Reply With Quote
Old 11-03-2005, 03:51 AM   #24
Car: Beater Van
After you guys installed your drain valve, what position was the lever? Was it perfectly straight or was it angled?
I just installed mine, and the top was at about a 10 o'clock postion. I was afraid to crank it to much as the instructions said turn in it 1/8 - 1/4 of a turn to tighten it.
Hawaii_guy
Old 11-03-2005, 09:29 AM   #25
I think mine ended up around 4- or 7-o'clock, so I was lucky. If it was going to end up pointing upwards, I was planning on unscrewing it and trying again.
Old 12-26-2005, 09:41 PM   #26
Car: 08 SSM STi
Fav Mod: Stock, for now
IWSTI Addict since: Jan 2005
Originally Posted by Datadatum
I had a nipple verson on my WRX, and it worked like a charm.
However, Fumoto highly recommends against the nipple for cars, so I got a regular one for my STi.
Just curious as to why they recommend against the nipple for the STi?
Old 01-09-2006, 06:50 PM   #27
Car: WRB 05 WRX STi
Fav Mod: Cobb AP
IWSTI Addict since: Jul 2004
can you use this with the stock oil temp sensor?? if not where would you have to put it to work?
hobsiscool is offline   Reply With Quote
Old 01-09-2006, 07:28 PM   #28
IWSTI Addict since: Oct 2003
I have personally seen a Fumoto open accidentally:
Fumoto valve warning
If you don't use something to lock the lever, it could happen to you. You have been warned.
Slowride is offline   Reply With Quote
Old 01-09-2006, 07:31 PM   #29
Rev
STI Guru
Car: 06 V70R
IWSTI Addict since: Dec 2003
Send a message via AIM to Rev
Guys. Safety wire your fumoto valve. You may never know
Old 01-09-2006, 07:46 PM   #30
Car: 08 STI SSM
Fav Mod: my wife
IWSTI Addict since: Sep 2005
Originally Posted by 2fas4u
If you get it from AMSOIL site they sell a safety ring that you put over the lever and it can not open without you removing the ring. I have one installed and it is great!
Jay
sounds good to me.
silver arrow is offline   Reply With Quote
