| Professional STI Racer Car: 05 OBP/Gold Fav Mod: TBE Location: Charleston, SC Posts: 667
IWSTI Addict since: Feb 2004 Trader Rating: (0) | I will be adventuring into ECU tuning here soon when I purchase the cobb ap. I was thinking about getting a Walbro 255lph Fuel Pump to go along with it. Is this acceptable and would it hurt if I got installed it with my current mods? Invidia TBE, K&N intake. Would I need anything else with a fuel pump to help out my car? This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by TRM; 10-26-2005 at 09:04 AM. Reason: clarified thread header for member convenience. |
| | #2 |
| Muller Chevrolet
Car: 09 DGM STi Fav Mod: beastly fenders Location: Milford, NJ Posts: 10,383
IWSTI Addict since: Oct 2004 Trader Rating: (11) | hell no, i have one. in fact, it'll help the stock injectors and is a safe mod. |
| | #4 | |
| Moderator Elite
Car: 2005 Subaru WRX STi Fav Mod: Underglows Location: Tyler, Texas Posts: 8,939
IWSTI Addict since: Jul 2005 Trader Rating: (0) | Quote:
| | #5 |
| Spec C Club Car: 06 Subaru WRX STi Fav Mod: My right foot... Location: Waterford CT Posts: 1,989
IWSTI Addict since: Nov 2004 Trader Rating: (1) | So, what exactly this Walbro 255lph Fuel Pump does? Does it pump faster and more fuel to the injectors? How is the gas consumption after the installation? What are the advantages/disadvantages? Lately, alot of members are using it. |
| | #6 | |
| Platinum Member Car: 05 STi & 05 LGT Fav Mod: My wifes 05 LGT Stage I Location: Mountains of NC Posts: 571
IWSTI Addict since: Jul 2004 Trader Rating: (0) | disadvantages: None Advantages: Taken from Scott Siegel reputable tuner Quote:
| | #7 |
| Professional STI Racer | Conversely you have guys like me, that have datalogged an STI on the stock pump, then changed the pump and datalogged it again, and saw NO difference in duty cycle, no A/F change.. Disadvantages there? Throwing 90 bucks in the garbage for absolutely no change in anything. Advantages?? Not a damned thing. Scott IS a reputable tuner, and in pretty much every case I stand behind what he says. But there is a reason why Gwinnet is the ONLY shop in the subaru community saying pumps make a difference. Because they dont. I swear that Gwinnet owns stock in Walbro or something ![]() (ok not really, just making a point) |
| | #8 |
IWSTI Addict since: Feb 2004 Trader Rating: (0) | I did a search on this as well and found many people arguing. It seems like the new fuel pump will just ensure that proper full is being supplied with the increased performance, boost from the Accessport. People spend was more money on body kits or other parts that don't serve a purpose but looks, so this couldn't hurt I guess. Where are some good dealers for this product and would yo urecommend the 255 or 225, etc.? Again I will be running stock turbo and be at stage two.. Is there a risk of running rich with a new fuel pump? Will it make idle roug hat all? |
| | #9 | |
| Professional STI Racer | Quote:
| | #10 | |
| Moderator & ECU Tech
Car: 05 CGM STI Fav Mod: mo boostaz Location: Fredneck, MD Posts: 3,759
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Quote:
"The bigger pump only supplies more FLOW, not pressure" Yes and no By default, pressure is created through flow. The flow comes first ... and then this creates the pressure. Yes, it does supply more flow. It also CAN supply more pressure in certain circumstances.Example: 43.5psi pressure in the rail with 18.5psi boost. The FPR (fuel pressure regulator) will now demand 62psi of fuel pressure (because subarus bump fuel pressure 1-to-1 with boost pressure). If the fuel pump can't keep up with the commanded fuel supply (ultimately determined by the Injector Pulse Width) ... then THIS is the situation where it can't sustain 62psi. The Walbro can sustain 62psi because it can flow more fuel. Thus, it can and does supply more pressure in cases where the stock pump can't keep up. When someone refers to a fuel pump as not being able to keep up, this is verified by the fuel pressure dropping or not reaching the target. Keep in mind that the correct walbro pump (GSS342) was created to supply more flow at a higher pressure. This means it can sustain higher pressures at a given flow better than many other pumps. In cases where you will see a pressure dropoff of the stock pump, you will not see this with the walbro (given normal stuff here guys - I'm not talking about 2 million cc injectors ). Put a 740cc Nismo injector with a stock pump and run it at 90% IDC. Fuel pressure will not reach target. Do the same thing with a walbro and it will reach target and hold pressure. It supplies more flow in this situation, and, therefore, more pressure.t | |
| | #11 | |
| Professional STI Racer Car: Silver 04 WRX STi Location: Dayton, OH Posts: 691
IWSTI Addict since: Sep 2003 Trader Rating: (0) | Quote:
offset | |
| | #12 | ||
IWSTI Addict since: Jul 2004 Trader Rating: (0) | Quote:
| | #13 | |
The one piece you are leaving out, is the only one that matters in this debate though. The factory FPR. Increased flow MAY create additional pressure UP TO the factory pressure reg, BUT the pressure reg is going to regulate that pressure down regardless. You still end up with the exact same pressure in the rails as with the stock pump.(this is why we install fuel pressure gauges in the return line and not the feed line) Unless you have changed the pressure reg, you will have the same exact pressure in the rails regardless of the pump (unless you are pulling more fuel than the factory pump can flow, which wont happen on the stock injects) | |
| | #14 |
| Muller Chevrolet
IWSTI Addict since: Oct 2004 Trader Rating: (11) | more flow = less stress on injectors bigger injectors = more fuel which needs the 255 on stock injectors, it's just what i stated earlier and prepares for any other potential upgrades...all in all i still think it's a great mod to do. |
| | #15 | |
Again, you are leaving the pressure regulator out of the picture. More flow= more flow to the pressure reg= exact same flow and pressure as before out of the pressure reg. More flow, combined with no pressure change= the injectors see absolutely nothing different. The ONLY reason you need the bigger pump is when you have bigger injectors, which are capable of sucking enough fuel down to lower pressure. The stock injectors do not flow enough to cause a pressure drop in the rail. This ad is not endorsed by this member. Please register or login to hide this ad. | |
| Thread Tools | |
