Old 09-04-2005, 02:39 AM   #1
Car: 01 Subaru WRX STi Spec C
IWSTI Addict since: Sep 2005
Default Motor Silk
Anyone ever put an oil additive called Motor Silk in their STI?
rx+roids is offline   Reply With Quote
Old 09-06-2005, 09:57 AM   #2
Car: 05 CGM STi
IWSTI Addict since: Jun 2005
You should put nothing but motor oil in the engine. Additives are BAD!!
solbergfan is offline   Reply With Quote
Old 09-06-2005, 10:35 AM   #3
Secret Moderator shhh
Car: '08 OBP
Fav Mod: A Car Wash
IWSTI Addict since: Feb 2005
Also, thats a reason to NOT use catrol syntec - it uses teflon as an additive which can soften engine materials in the long run. Its a no no
Jeff
sgtpeper is offline   Reply With Quote
Old 09-12-2005, 10:46 AM   #4
Car: Your STi ;)
Fav Mod: Everything
IWSTI Addict since: Mar 2005
NO! NO! NO! NO! NO! NO! NO!
Motor silk is what we "believe" DESTROYED an entire motor. It clogged ALL the small hard oil lines. It destroyed the turbo (exhaust wheel found in DP), crank bearings (BAD rod knock), heads and cams (ALL bearing surfaces scored beyond use).
We haven't proven it yet, but they are being given the $14,000 bill!!!
SS
Old 09-12-2005, 10:52 AM   #5
cruzSTI is offline   Reply With Quote
Old 09-12-2005, 10:54 AM   #6
IWSTI Addict since: Apr 2004
Originally Posted by Subaru of Gwinnett
...It destroyed the turbo (exhaust wheel found in DP...
The WHEEL was in the DP??? Juheesus. And there was still some oil in the case?
Old 09-12-2005, 11:13 AM   #7
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
IWSTI Addict since: Jun 2004
Trader Rating: (14)
what about fuel additives, like BG44K?
BoostJunkie is online now   Reply With Quote
Old 09-12-2005, 02:29 PM   #8
Fav Mod: Track Day!
IWSTI Addict since: Nov 2003
That's used to clean the engine (combustion chamber).
An 04-06 Sti doesn't need the engine cleaned.
TreyS is offline   Reply With Quote
Old 09-13-2005, 07:46 AM   #9
Car: 05 CGM STi
Why would the STi not need the engine cleaned? Does the EJ257 not produce carbon build up in the combustion chambers??
Actually the reason why I wouldn't use the BG TEC is I would be afraid that pieces of carbon exiting the exhaust port could damage the turbo impeller.
Old 09-13-2005, 12:16 PM   #10
Car: 05 Subaru CGM STI
Fav Mod: Turbo Belt FTW!!!!
Bronze SEMA 2007 Sponsor
What about adding stuff like octane booster to your fuel? I know that I should only put oil in the engine but what about trying to add octane to your fuel. Could this hurt anything? Just wondering because I get caught driving out in the country and there is only 92 octane and would like to add a octane booster to at least be around 94 octane. Any information would be appreciated.
Trey
Trey05STI is offline   Reply With Quote
Old 09-13-2005, 12:23 PM   #11
Car: O5 OBP STi
Fav Mod: Volk LE28N
IWSTI Addict since: Jul 2004
Send a message via AIM to Sti-lysh
If I am not mistaken, you have to add a hell of alot of octane booster to go from 92 to 94. Those things on raise the number by points. i think one octane number is ten points, and those boosters raise the fuel like 5-7 points. But someone correct me if I am wrong.
Sti-lysh is offline   Reply With Quote
Old 09-13-2005, 02:14 PM   #12
Fav Mod: 4th gear wheelspin
IWSTI Addict since: Nov 2004
MMT-based octane boosters work. Torco seems to be the best but the NOS Racing Formula octane booster works in a pinch and can be found in many auto parts stores. I wouldn't touch anything that is not MMT-based.
