Old 09-02-2005, 09:38 PM   #1
Car: 05 Subaru WRX STI Wh
Fav Mod: Invidia N1 catback, Helix DP
IWSTI Addict since: Jul 2005
Angry I failed installing my helix dp!!!! Catback is on though.
I received my invidia N1 catback back on Aug. 27 and it took about an hour and a half by myself to put on. Really easy. However today my Helix dp came in today so I left work early to put it on. After taking the tmic off and the heat shield I was ready to take off the dp. Holy sh!t man those bolts were impossible. I sprayed them with everything on this earth to help me get them off. I could only get one off and loosen another. Im no weak guy so I didnt think this would be a problem. WRONG!!! After trying an impact ratchet, breaking bar, etc. I decided to give up. I put the car back together and called a local shop and they will be putting it on for me on Tue. at $75 an hour. If it werent for bad luck id have none. I do love the sound of the invidia catback though so its not a total waist. Just thought id share my experience with you people.
speedjunkie is offline   Reply With Quote
Old 09-02-2005, 11:47 PM   #2
Car: 1983 Mercedes Benz 3
IWSTI Addict since: Feb 2004
Best way to remove exhaust bolts is with a $10 butane torch. Actually, you don't remove them with the torch, but heat the bolts up. Works like a charm.
Ol'SaltyBastard is offline   Reply With Quote
Old 09-02-2005, 11:49 PM   #3
Fav Mod: Motor Mounts
IWSTI Addict since: Oct 2004
Make sure they port your wastegate housing...
Old 09-03-2005, 02:18 PM   #4
Wouldnt that be more time and money? This is something that I did not plan on doing when I tried it by myself
Old 09-03-2005, 02:27 PM   #5
Car: '06 Evo IX, '05 STi
Fav Mod: Boost =]
IWSTI Addict since: Apr 2005
Do you have any friends that could do it for you?
TeKiZeRo is offline   Reply With Quote
Old 09-03-2005, 02:37 PM   #6
all of my friends have different cars than mine. I unfortunately am the most mechanically incined out of all my buddies
Old 09-03-2005, 03:12 PM   #7
Yes...but it shouldnt be too bad. You will boost creep if you dont = bad....just make sure they know what their are doing.
Old 09-04-2005, 12:34 AM   #8
so what you are saying is when I get to the shop to change my downpipe I should also get pricing on porting my wastegate housing? I hope its not to much more.
Old 09-04-2005, 07:55 AM   #9
Yes. There are writeups with pictures all over the web, most guys do it themselves (you need a compressor, die grinder, and a carbide cone bit...oh and your wastgate housing). Most of the work will be done since you are changing out the DP anyways...your wastegate housing is right there. Search "boost creep" here and on nasioc. Ill see if I can find the write ups for you too. Just make sure you do a little homework first. Your car will thank you for it and it will be cheaper in the long run.
Old 09-04-2005, 08:02 AM   #10
here...this is a good writeup
http://www.pghsubarus.com/tech/porting/porting.aspx
Old 09-04-2005, 08:08 AM   #11
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (54)
speedjunkie,
where are you located?
Old 09-04-2005, 09:38 AM   #12
Fav Mod: Track Day!
IWSTI Addict since: Nov 2003
Did you use PB Blaster on the bolts/ nuts? That works for me everytime.
TreyS is offline   Reply With Quote
Old 09-04-2005, 10:30 AM   #13
IWSTI Addict since: May 2003
This isn't always necessary.
evoklr is offline   Reply With Quote
Old 09-04-2005, 10:53 AM   #14
sponge worthy
Send a message via Yahoo to gixxer6
^^^ yeah i don't think there is that many people porting the wastegates anymore. i think the 04's might have been a little worse to get creep than the 05's are. if you are getting some sort of engine management i wouldn't worry about porting the wastegate, em usually takes care of any creep you might get.
gixxer6 is offline   Reply With Quote
Old 09-04-2005, 10:55 AM   #15
I am located in Waldorf, MD. I did use pb blaster on the bolts. It helped with two of the bolts. I started to round them off so I stopped messing with it before I had bigger problems to deal with. I am glad it didnt work out for me seeings I need to port my wastegate. Thanks for that useful link. I will definitely do my homework from now on even if it seems like the easiest of upgrades. Any suggestions on a good shop in the Maryland area????
