| | #16 |
| Amateur STI Driver | Try GM/Goodwrench Heat Valve lubricant or Mopar Heat Riser solvent (same stuff, i think). I believe it's for frozen EGR valves. They go for about $5 at the parts counter. Spray liberally and let sit 10-15 min. I alway use this stuff on exhaust bolts or anywhere I'm worred about breaking a bolt or stud. Also, I always try to do exhausts when the car is still warm (be careful and use gloves!) This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by gromit555; 09-04-2005 at 11:19 AM. |
| | #18 | |
| Senior STI Driver Car: 2005 STi White/Silv. Fav Mod: Brick on the gas pedal Location: Port Orange, FL Posts: 347
IWSTI Addict since: Dec 2004 Trader Rating: (0) | Quote:
| | #19 |
| Spec C Club Car: 04 STi Fav Mod: Motor Mounts Location: Eugene Posts: 2,300
IWSTI Addict since: Oct 2004 Trader Rating: (0) | If you run catted you should be alright...me on the other hand w/o any cats and an 04 to boot had problems...and ive seen pleanty of 05's that have had the same prob... |
| | #21 | |
| Professional STI Racer Car: 04 WRB/ GOLD STI Fav Mod: snail sticker = 5hp Location: Raymore, MO Posts: 792
IWSTI Addict since: Feb 2003 Trader Rating: (0) | Quote:
| | #22 |
| Professional STI Driver Car: 07 S204 WannaBE Location: NW Subs, Chicago Posts: 491
IWSTI Addict since: Jun 2005 Trader Rating: (1) | dude dont waste the money on getting someone else to do it because their not going to have it any easier then you, and might loose their petience and just bang it in there. I just did my downpipe install so I know what your going thru. It was all about not having good enough leverage. Climb into your engine bay, ahve someone hold the hood completely open, stand on the peice powder coated red, and have at it with those nuts. You get a great vantage point from standing on your engine and it wont hurt nothing. Those bolts dont stand a chance. -Foo |
| | #24 |
| Spec C Club
Car: 05 AW 30r STi Fav Mod: Perrin 30r Kit Location: Campbell Hall, NY Posts: 1,565
IWSTI Addict since: Apr 2005 Trader Rating: (5) | just get a bar and put it over the end of the wrench like someone else did, and just pull it. it should come off pretty easy. leverage helps so much with tight bolts, i was trying to change my friends rotors and couldnt get the bolt off for anything...kicking it pull it as hard as i could. put the bar on and it came off with ease. kinda felt like a jackass for not realizing sooner. also spray it with some pb blaster or lubricant u can find and you should be set. |
| | #25 |
| Professional STI Driver | i did the install with about 4K miles on the odo. used pb blaster, and only a craftsman 14mm wrench,(for the dp bolts) i'm a bit stronger than most folks, but only the one bolt under the tmic, gave me trouble, that and fiddling with the top heat shield to get it out took the most time. |
| | #26 |
| Silver Member | there's a little trick that sometimes works, especially on bolts that are stuck because the studs are rusted... Carefully, try to TIGHTEN the nut just enough to break it free, then hit it with more pb blaster and off it'll come... use discresion though, but it does work. |
| | #27 | |
Car: 05 WRB STi-SOLD Fav Mod: Blown V8 Conversion Location: NE FL Posts: 695
IWSTI Addict since: Jul 2005 Trader Rating: (0) | Quote:
| | #28 |
| Senior STI Driver Car: 05 Subaru WRX STI Wh Fav Mod: Invidia N1 catback, Helix DP Location: waldorf, MD Posts: 372
IWSTI Addict since: Jul 2005 Trader Rating: (2) | Im going to give this stuff a try. I will attempt on Fri.. I did use the bar off my jack to get leverage but all that would happen is the wrench would start to round the nut. Man I hope they come off. I have the cat back on now should I expect a big difference once the down pipe is finally on?? sound, power etc....???? |
| | #29 |
IWSTI Addict since: Jul 2005 Trader Rating: (2) | Well i finally got my downpipe on my car. After getting these special sockets for stripped nuts, and actually having to use the dremel on one of the nuts it's on. Thanks for all your help and advise. Man this exhaust makes me ride around with permaboner. That's right permaboner!!!!!!! |
| | #30 | |
| Gold Member Car: 04 WRB STi Fav Mod: ACPT CF DS + Cobb Stg 2 Location: Central TX Posts: 1,048
IWSTI Addict since: Apr 2004 Trader Rating: (3) | Quote:
