Old 08-24-2005, 02:59 AM   #1
Car: 06 s2000
Fav Mod: G2X data logger
IWSTI Addict since: Jul 2005
Default gt30r with stock STI tmic
around where should a gt30r with the stock sti tmic get full boost at? i really want to keep my stock tmic rather than go with a fmic. im into road course so i want a turbo with minimal lag but great top end when needed. has anyone ran this particular setup before or know anyone? any info would be great.
-AJ
kettsupp is offline   Reply With Quote
Old 08-24-2005, 09:45 AM   #2
IWSTI Addict since: Apr 2004
Originally Posted by kettsupp
around where should a gt30r with the stock sti tmic get full boost at? i really want to keep my stock tmic rather than go with a fmic. im into road course so i want a turbo with minimal lag but great top end when needed. has anyone ran this particular setup before or know anyone? any info would be great.-AJ
Depending on how high you're running the boost and how tight your set-up is, they can achieve full boost @ 3.5-4.0k with a FMIC, so I'd imagine a couple of hundred rpm lower with the stock TMIC. FWIW, however, I can't think of a single tuner that would recommend running a true Garrett GT30R without a FMIC. I certainly don't intend to, but that's just me.
You've read that the STi gets no positive air flow from the scoop above @ 100mph due to the separation of airflow off the hood, right? IOW, the scoop supposedly experiences negative air pressure and actually sucks hot air out of the engine bay through the TMIC. I can't say for certain if that's really true or not, but I'd sure do some serious research before I stuck a big blower on the car with no FMIC and road raced it. That's my $0.02.
Old 08-24-2005, 10:24 AM   #3
Car: 06 s2000
yea, i know a fmic would be the way to go but im just searching for answers if anyone has any good info with keeping their stock tmic on before i go ahead and do it.
Old 08-24-2005, 11:26 AM   #4
Car: my STI
Fav Mod: Sr. loan officer
IWSTI Addict since: Dec 2004
Send a message via AIM to tuswm Send a message via MSN to tuswm Send a message via Yahoo to tuswm
I was interested in the same thing.
This is about the GT35 kit but they also do the GT30R kit if you ask for it. ITs not the stock TMIC but it is TMIC. I think this is the closest you will get.
good luck
tuswm is offline   Reply With Quote
Old 08-24-2005, 04:48 PM   #5
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
you are going to get heatsoak like crazy with the stock tmic. atleast you should try to go with an aftermarket one. but if you are using the car for the track (road course, not auto-x) then having a fmic wont make a difference in lag, since you should always be in the meat of the powerband.
