C0047 and C0054 Error code - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > C0047 and C0054 Error code
Old 03-19-17, 07:08 AM   #1
STi-mon
Becoming A Contributor
Car: Black Opal 2011 STi
Fav Mod: COBB Accessport
STi-mon is an unknown quantity at this point
Default C0047 and C0054 Error code
Hey everyone!
So I have a C0047 and C0054 error code in memory.
I've been reading up and apparently it would have something to do with the ABS Wheel Speed Sensor.
1) Has anyone ever had these codes pop up and how did you fix it?
2) Is there an ABS Wheel Speed Sensor for each wheel meaning that it becomes a guessing game of which is faulty or is there only one?
Thanks
STi-mon is offline
Old 03-22-17, 03:28 AM   #2
Jay11STI
Advanced Mastery Level I
Feedback Score: 2 reviews
Car: 2011 SWP STi Sedan
Jay11STI will become famous soon enoughJay11STI will become famous soon enough
Default Re: C0047 and C0054 Error code
What do the codes say specifically?? Any warning lights displayed on the cluster? How does the car run? Miles? Mods? Any work done recently on the car?? We need more info. We are not mind readers and we cant help diag anything like this online without more information.
Yes each wheel has its own wheel speed spensor.
Jay11STI is offline
Old 03-22-17, 05:17 AM   #3
STi-mon
Car is stock except for Cobb Accessport but issue occured before Accessport install so I know it's not that.
There are no warning lights on the dash only the C. Diff Lock will start blinking.
Car runs as it should, I can still change between all there drive modes (Intelligent, Sport and Sport#) and I can deactivate the stability control no problem. The only thing I can no longer do when the error occurs is choose my DCCD setting.
The problem is completely sporadic, but at first I though it was when it was too cold but this morning it was cold and it didn't pop up.
Is it possible for snow or slush to mess with the sensors or causing a short in them? It's the only idea I can come up with but it would be stupid if that was the case seeing as the car is made for winter IMO.
STi-mon is offline
Old 03-22-17, 07:40 AM   #4
Jay11STI
What did the codes say specifically? Were they specific to a certain wheel speed sensor? You can also inspect all of them to see if there is any visible damage to them and the wiring.
Jay11STI is offline
Old 03-22-17, 08:34 AM   #5
STi-mon
Unfortunately I don't have any other info to go on at the moment. I will try to adjust the brake light switch and see what happens.
Do certain fluids or oils affect the DCCD?
Next step is to inspect the sensors to see if any were affected due to snow. My only problem is I'm not set up to be able to remove and replace wheels easily making the task a lil more difficult.
STi-mon is offline
Old 03-22-17, 01:11 PM   #6
STi-mon
So now problem only seem to occur when driving over 100km/h after prompt acceleration.
STi-mon is offline
Old 03-24-17, 10:26 AM   #7
STi-mon
Problem solved!!!
So I went to the dealership to see if there is an issue but prior to my appointment I went and got the car washed. After the wash was done the problem has yet to reaccur. So I spoke to the service specialist and he tells me that it's normal.
Turns out the sensor acts like a magic eye that counts the number of "teeth" on a piece that rotates with the wheel. If ever snow, ice or slush fils those "teeth" the sensor gets an irregular count and pop goes the warning light (in this case the DCCD indicator.
I'm happy problem is solved but disappointed that a car that is suppose to be a rally inspired vehicle meets its maker because of snow or slush...
Ah well just happy it's solved and someone was able to explain the issue.
STi-mon is offline
