coolant problem 2012 sti sedan - Subaru Impreza WRX STI Forums: IWSTI.com
STI Products
Go Back   STI Forums > > > coolant problem 2012 sti sedan
Old 03-14-17, 07:31 AM   #1
charcoal2012sti
Active Participant
charcoal2012sti is an unknown quantity at this point
Default coolant problem 2012 sti sedan
hey guys i have a 2012 sti sedan lately ive noticed if i drive my car hard the coolant burps out of the reservoir and the fill tank was empty anf the car overheated and went into limp mode but if i drive the car normal is runs normal with no problems i thought maybe water pump but wouldnt it have the problem all the time if it was the water pump any help i would greatly appreciate thanks
charcoal2012sti is offline
Old 03-14-17, 07:37 AM   #2
yamahaSHO
BROtuner
Feedback Score: 7 reviews
Car: 2005 WRB
Fav Mod: Equal Length Header
yamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud of
Default Re: coolant problem 2012 sti sedan
You're pushing exhaust gasses through the head gasket and into the coolant passages. You have to remove the heads and replace the head gaskets. I recommend having the heads skimmed, using head studs, and new OEM gaskets when you put it back together.
-Jason
yamahaSHO is online now
Old 03-14-17, 08:24 AM   #3
charcoal2012sti
Active Participant
damn that sux thanks for the advise i guess a few mortgage payments at the shop again
Old 03-14-17, 10:40 AM   #4
yamahaSHO
BROtuner
Car: 2005 WRB
Honestly, this is a pretty easy fix. I've had customers does this in a couple weeks in their garage and taking their heads in to be skimmed and vacuum seat tested.
-Jason
Old 03-14-17, 12:59 PM   #5
Jay11STI
Developing Advanced Mastery
Feedback Score: 2 reviews
Car: 2011 SWP STi Sedan
Jay11STI will become famous soon enough
This is a very good possibility but first things first. To the OP, are there any coolant leaks what so ever? Have you topped off the coolant correctly and re-bled the cooling system correctly. Have you pressure tested the cooling system yet?
How many miles are on this car?
Jay11STI is online now
Old 03-14-17, 01:04 PM   #6
yamahaSHO
BROtuner
Car: 2005 WRB
Willing to bet money that I have it spot on.
-Jason
Likes 2 Dislikes 0
Old 03-14-17, 03:55 PM   #7
charcoal2012sti
Active Participant
yeah i think its the heads cause now that ive been looking into it when i boost it feels like im loosing everything sometimes at like 5500 its like it just loses boost i figure if its the heads i might as well change the pump the belt plugs and see how the clutch and flywheel look because the engine has to come out to remove the heads if im not mistaken
Old 03-14-17, 04:31 PM   #8
Jonnywachter
Advanced Contributor Level 1
Feedback Score: 1 reviews
Car: 10' Red STI hatch
Fav Mod: Speedhut gauges
Jonnywachter is on a distinguished road
I had the exact same issue with my 2010 STI, I too was told its the HG. I did a ton of research and not one person pointed me in any other direction EXCEPT for one. It was suggested that the radiator cap might be bad. When the car is driven hard, pressure builds in the coolant system and if the radiator cap spring had gone bad, can show the same exact signs that a blown HG shows. I replaced my radiator caps and my car is running perfect. There are other ways to test this. Get the coolant checked for oil/exhaust fumes, check the oil for coolant... ect... but for something around $45 dollars VS pulling the heads and all that... its worth a shot.
I was having the same exact issues you described in your original post. BTW
Jonnywachter is offline
Old 03-14-17, 05:06 PM   #9
Jay11STI
I'd prefer to diag before recommending a head gasket job. I've had head gasket failure on other cars that showed similar issues. But I've learned that head gaskets can be tricky on all cars since every car is different.
I didn't even think about the radiator cap being an issue. I think its definitely worth a shot before doing the big job. Just imagine getting beat by a radiator cap after you've pulled the heads lol
Old 03-14-17, 05:11 PM   #10
yamahaSHO
BROtuner
Car: 2005 WRB
Pretty easy to diagnose. OP, do you see tiny black particles floating around in your overflow?
-Jason
Privacy Policy
