coolant problem 2012 sti sedan - Page 2 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > coolant problem 2012 sti sedan
Old 03-14-17, 05:25 PM   #11
Jonnywachter
Advanced Contributor Level 1
Feedback Score: 1 reviews
Car: 10' Red STI hatch
Fav Mod: Speedhut gauges
Jonnywachter is on a distinguished road
Default Re: coolant problem 2012 sti sedan
Originally Posted by Jay11STI View Post
I didn't even think about the radiator cap being an issue. I think its definitely worth a shot before doing the big job. Just imagine getting beat by a radiator cap after you've pulled the heads lol
My thoughts exactly, I believe you can get a radiator cap test kit from autozone, they should hold pressure to 1 or 1.3 bar. Just in case you didn't want to spend the $45 dollars first.
Jonnywachter is offline
Old 03-17-17, 05:35 PM   #12
charcoal2012sti
Active Participant
charcoal2012sti is an unknown quantity at this point
ive read a thread about a similar problem of course i forgot where i read it but it also says that the oem head bolts heat up and stretch while boostin and let air in the coolant passages resulting in the coolant being pushed outta the reservoir ill keep this updated as i go along to help anyone having the same problem actually seems common
charcoal2012sti is offline
Old 03-17-17, 07:12 PM   #13
yamahaSHO
BROtuner
Feedback Score: 7 reviews
Car: 2005 WRB
Fav Mod: Equal Length Header
yamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud of
It's not air, it's exhaust gasses.
-Jason
yamahaSHO is online now
Old 03-18-17, 07:19 AM   #14
charcoal2012sti
Active Participant
my bad exhaust gases right do you have any recommendations on parts ive been reading that oem is the way to go for the timing bely and pulleys and water pump but what about head gaskets and head studs ?? also what about a clutch and flywheel as of now i plan on keeping the car stock as i kinda have to use it as a dd any feed back on parts is welcome
Old 03-23-17, 06:55 AM   #15
NWIEBE147
Becoming A Contributor
Car: WRB 2010 STi
Fav Mod: Pfftt
NWIEBE147 is an unknown quantity at this point
When was the last time you changed the thermostat? If the jiggle valve is not clocked at the 12 o'clock position the system will become over pressurized. Just a idea but it does sound like the HG.
NWIEBE147 is offline
Old 03-26-17, 01:22 PM   #16
charcoal2012sti
Active Participant
update so i went and got the car checked out and its the HG so now its time to gather up a parts list so any suggestions on what to change while i pull the engine are welcome thanks guys for the help
Old 03-26-17, 11:10 PM   #17
yamahaSHO
BROtuner
Car: 2005 WRB
For most people that I recommend this fix action, I assume you're not building some massive dyno power number, I always say:
- OEM head gaskets
- Have the heads skimmed (clean the block surface yourself, carefully)
- ARP head studs
- Put back together properly.
- Generally worth replacing the timing belt, tensioner/idlers, water pump, etc while it's all out.
-Jason
Likes 1 Dislikes 0
Old 03-30-17, 01:44 PM   #18
Jay11STI
Advanced Mastery Level I
Feedback Score: 2 reviews
Car: 2011 SWP STi Sedan
Jay11STI will become famous soon enoughJay11STI will become famous soon enough
Willing to bet money that I have it spot on.
Yup you called it! Good thing I didn't take that bet LoL I guess you have seen this issue before to know this exactly.
Jay11STI is offline
Old 03-30-17, 06:25 PM   #19
charcoal2012sti
Active Participant
- OEM head gaskets
- ARP head studs
exactly the route im taking the car is a daily all stock motor got the head studs on the way appreciate all the feed back anything other ideas im open to. my first subaru and i want to keep it as healty as possible
