In the middle of a Tomei turbo inlet install since my stock inlet tore. Everything seemed to be going smoothly until I put on the bpv return line then attempted to put on the throttle body. As you can see in the pic, the bpv is kinked and I'm not seeing a reroute that will open it up. Am I missing something here? Any suggestions or maybe ok running it as shown?
Running approx. 21psi on E85 if it helps. Any advice is greatly appreciated!!
