DIY slosh box/in tank fuel cut eliminator - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > DIY slosh box/in tank fuel cut eliminator
Old 06-25-11, 05:47 AM   #1
2.5 turbo hyped
Advanced Mastery Level I
Feedback Score: 1 reviews
Fav Mod: Carbon/Kevlar Karlton's flares
2.5 turbo hyped is an unknown quantity at this point
Default DIY slosh box/in tank fuel cut eliminator
Most of you already realize once you go with an aftermarket pump or dual pump in tank setup you may get fuel cut particularly around 1/3 or less of fuel.
The main cause of this being the poorly designed slosh box that most people do not reinstall when adding an aftermarket pump.
I am running E85 and want to fabricate something that will help get the STI around those corners without it falling on it's nose.
I am currently testing (bench) a rain-x windshield washer fluid bottle to see how it holds up to E85. What I then want to do is cut it up and install it so that it engulfs the 2 fuel pump filter/strainers. I am running a dual setup so this may vary for some of you.
I figure if I drill 2 1/8" holes in various locations that it may flow slow enough to keep the fuel pumps submerged on a corner.
Thoughts? Anyone else already tackled this without the use of a surge tank?
Check out my journal here http://www.iwsti.com/forums/gd-membe...ds-inside.html
Tons of pictures of all of my DIY projects can be found here http://www.putphoto.com/sti2nr
Visit my youtube page http://www.youtube.com/sti2nr2
2.5 turbo hyped is offline
Old 08-09-11, 04:39 PM   #2
2.5 turbo hyped
Default Re: DIY slosh box/in tank fuel cut eliminator
Problem solved!!!!
13 bucks =
Old 10-31-12, 06:28 PM   #3
13larry
Joined the Conversation
13larry is an unknown quantity at this point
Does the opening lay flat in the tank?
13larry is offline
Old 12-16-12, 10:34 PM   #4
BigKuma
Car: Silver 00 2.5RSTurbo
Fav Mod: Engine block heater
BigKuma is an unknown quantity at this point
This looks really cool. I have a huge problem with fuel cutting out in turns. I want to make something like this too.
Did this solve the fuel cut problem completely ?
How does having this affect your max fuel capacity ?
Does dumping the hot fuel next to the pump affect the performance ?
On my RS, there is a little partition box for where the fuel pump strainer rests on the bottom of the tank. Do you have that on the STI ? Did you remove that ?
BigKuma is offline
Old 08-01-15, 05:45 PM   #5
sirclesam
Contributor
Car: 01 RS
sirclesam is an unknown quantity at this point
Looks like it did help this guy:
Shanes impreza fuel slosh mod - Ludicrous-Speed
sirclesam is offline
