| | Thread Tools |
| Approaching Technical Contributor Feedback Score: 8 reviews Car: Black 07 wrx sti Fav Mod: one that does not blow my motor up | ATP email: "It's quite easy to diagnose. You have breather hoses coming out of each side of your engine (valve covers). There are two breathers on each side of the engine. Two of them merge alongside the topmounted intercooler and two of them merge near the compressor inlet.If, when you modified the breather port near the compressor inlet, you compromised the vents or "plugged" them, then you've got trouble. What happens is if you compromise the engine's breather ports and the engine is not allowed to vent the crankcase, the positive pressure will build inside the engine's case. What then happens is the pressure will find its way up the oil return line into the turbo since the oil return tube is directly connected to the engine's crankcase.The reason the turbo leaks oil is because oil that is trying to drain out of the turbo has nowhere to go (blocked by pressure blowing upwards from the crankcase into the oil return line). The oil is then *designed* to leak out of the shaft seals and that is how you ended up with all that oil in the comp housing and subsequently in the charge pipes.Good news though:If you clean up all the oil and fix the blockage in the breather ports, the turbo will work just fine again and no harm is done." So today i went over all my PCV breather lines and pulled the PCV valve and the lines are run correctly (for the APS turbo inlet). I also checked the valve (shook it and it sounds like its still good) and it is ok. My questions are: what is causing my crank case to pressurize and cause my turbo to leak? Does APT's diagnoses make sense? Modes (not all just the main ones): ATP GT3582R (stock location) Perrin FMIC Aquamist HFS5 (90/10 mix) 850 cc injectors TGV deletes Equal length headers Element down pipe Invidia 3" race N1 Cobb AP KS tech CAI APS turbo inlet |
| Thread Tools | |
Similar Threads | ||||
| Killer B Ultimate Oil Pickup / Optimal Oil Pan Group Buy – Individual items or Combo! | IAG Performance | Vendor Group Buys | 33 | 05-11-10 02:26 PM |
| Awesome oil: 1.5yrs & 20K miles of testing, Daily Driver, WOT every day | WolfPlayer | 2.5 Liter/Litre Factory Motor | 33 | 08-13-09 04:51 PM |
| please explain | torquemada | Warranty / Service Issues | 6 | 07-24-08 11:08 AM |
| Top 10 most stolen cars 2007 for each state | fourseasonsandles | Off Topic | 17 | 07-18-08 07:42 AM |
