Old 02-07-2010, 02:58 PM   #41
Car: 2005 WRB
My StuffSubaru Parts
Fav Mod: Driver
IWSTI Addict since: Oct 2007
Default Re: Looking to run E85 on a 20g
I think I'll be forced to have a louder intake. I wasn't too fond of the noise when I had the SPT, so I picked up a stock intake. I don't like the idea of the filter in the fender as I already deal with that on the SHO.
I think I may pickup 850cc injectors and an adjustable FPR and start with gas. When I tune for E85, I'll bump up the pressure and see if I'll need a secondary pump. I'll likely be researching another week
yamahaSHO is offline   Reply With Quote
Old 02-09-2010, 07:27 AM   #42
Car: WRB 08 STI
Fav Mod: 20g/ E85
IWSTI Addict since: May 2007
A single Walbro and 1000 cc injectors for a 20g on E85 will be more than enough. I modded my stock injectors and they are now 1015 cc and I have a single Walbro. I ran 22 psi on teh E85 map with the FP TD06 20g. I will turn it up a little more the next time I fillup with E85. I am running 91 oct currently.
blkscooby is offline   Reply With Quote
Old 02-09-2010, 08:24 AM   #43
Car: WRB/Gold 08 STi
Fav Mod: E85 smell
IWSTI Addict since: Jul 2008
I am running a td06h 20g with dw850s on e85 as well, and my idc is 85% at wot boosting 23psi. Other than a walbro and injectors my fuel system is stock.
burnstacp is offline   Reply With Quote
Old 02-09-2010, 10:23 AM   #44
Car: 2005 WRB
Fav Mod: Driver
Are those large injectors playing nicely for idle and cruise?
Have you traveled to lower altitude with that setup? You're WAY up there and air/fuel requirements will be different. Where are you hitting your max IDC, at peak boost or RPM?
Old 02-09-2010, 08:01 PM   #45
Fav Mod: E85 smell
Not sure where I am hitting it at. I just check what the max amount was during a pull. I have not checked it at sea level, but I have driven down there on E85. I usually end up maxing out my MAF and put it into limp mode, so I run 93 instead until I can swing by COBB and get a sea level tune (and possibly upgrade the MAF).
Old 02-10-2010, 07:07 AM   #46
Car: 2005 WRB
Fav Mod: Driver
I think I'll hold off on this decision until DW comes out with the 1000cc side feed injectors and see what they say about them. I may try stock fueling and add the pump and injectors and tune from there. No need in changing out things if they don't need to be.
Old 02-10-2010, 07:09 AM   #47
Formerly 240sxsexy
Fav Mod: Coolingmist CMGS-FS
IWSTI Addict since: Aug 2009
Has DW said anything about making 1000cc side feeds?
BAD STI is offline   Reply With Quote
Old 02-10-2010, 09:37 AM   #48
Car: 2005 WRB
Fav Mod: Driver
Yes.
Old 02-10-2010, 12:43 PM   #49
Car: MY06
Fav Mod: Valentine-1
IWSTI Addict since: Jun 2006
Do you know when they would be out. ^^^
superhero06 is offline   Reply With Quote
Old 02-10-2010, 12:57 PM   #50
Car: 2005 WRB
Fav Mod: Driver
They are in testing right now, as I'm told. They can't pin-point a date at the moment, but mentioned *possibly* 2 - 3 months.
Similar Threads
2007 STI LTD - 547whp/471wtq (E85) COBB Tuning Power Bragging 13 03-09-2010 06:46 AM
NEW: AMR 20G Bolt On Turbocharger!!! (AMR 20G hangs with the big boys!) AutoMaster Vendor Announcements & Project Buildups 7 02-24-2010 09:27 AM
NEW: AMR 20G Bolt On Turbocharger!!! (AMR 20G hangs with the big boys!) AutoMaster GR-Vendor Announcements 3 01-18-2010 07:43 AM
Blouch 20g & Dominator Turbo Deals|Cobb AP's|TurboXS|Perrin|Invidia|DW Injectors Spun Autosports GR-Engine/ECU/Power/Drivetrain Classifieds 54 10-05-2009 02:55 AM
Follow up on Cobb Tuning's 20G calibrations for the AccessPORT Christian. ECU Tuning & Performance Electronics 14 08-26-2006 11:18 AM
Privacy Policy
