Old 08-25-2008, 07:11 PM   #11
IWSTI Addict since: Mar 2006
Default Re: The ULTIMATE header!
Originally Posted by Iron Giant View Post
All of the ceramic companies I have contacted insisted that doing wrap on top of coating causes some serious issues. The first being extreme stress on the header itself due to too much heat retention (the same reason why you shouldn't wrap a header twice or overlap too much). The other issue that they mentioned was that the wrap has a tendency to ruin the ceramic coating pretty quickly.
That being said I genuinely hope that you prove them wrong
Both very valid points that I hope to have addressed. I both did my best to lay down a reasonable and even wrapping while trying to prevent uneven expansion especially around welds near the flanges. Without a thermal gun who knows how well I did though.
Also, the Swaintech white lightning coating is baked on at many thousands of degrees and rated to about 3000 F. I doubt the measly 1800F I see on the track will affect this coating.
Literature:
White Lightning Exhaust by Swain Tech for Automotive Coatings including engine piston coatings, ceramic coating services engine, automotive ceramic coating, ceramic header coating, dry film lubricant, race engine coatings, exhaust header coating
And if all of this fails, I've got the good old stock manifold in a box
EDIT: Did you contact swaintech concerning wraps and their White Lightning coating?
Tgui is offline   Reply With Quote
Old 08-25-2008, 07:48 PM   #12
Well, wrap is pretty damned easy to install in the scheme of things. Since I now have a sense of how well wrap retains heat, I might just tear it off tomorrow and take a better look at the EGTs with just the ceramic coating.
Yes, I should have take better notes prior to the wrap.
Will also call swaintech tomorrow.
Yes, I saw lots of conflicting articles on the net.
Privacy Policy
