Old 01-06-2008, 01:24 PM   #1
Car: 04 subaru sti
Fav Mod: greddy turbo t67
IWSTI Addict since: Apr 2006
Angry WTF another problem help me out guys
So we catch a nice day in frigid ohio and what do you know the sti won't start. 2 weeks ago starts up fine and today i get nothing just crank, crank, crank and it never starts. Some interesting things about this problem, its acting like it's not getting fuel and i dont hear the pump prime but i just replaced the walbro 3-4 months ago so i doubt its that but how knows, also my dccd lights are doing the thing where the bottom green one flashes and im wondering if this has an anything to do with my car not starting. The last time it was drivin it was perfect running easy starting no problems at all and that was maybe two weeks ago and now this any help would be greatly appreciated
thornton22050 is offline   Reply With Quote
Old 01-06-2008, 01:53 PM   #2
Car: 2005 OBP STi
Fav Mod: CBE
IWSTI Addict since: Aug 2006
Default Re: WTF another problem help me out guys
my only advice over the web is to check all fuses either by pulling them out, or with a test light. its verry possible the fuel pump fuse could have gone.
johnlude85 is offline   Reply With Quote
Old 01-06-2008, 01:55 PM   #3
STI Master
Fav Mod: Whooshing sounds
IWSTI Addict since: Nov 2003
Is the battery good?
Old 01-06-2008, 03:22 PM   #4
Car: 05 WRX STI OBP
Fav Mod: Fixed interest rate!! yay!!
IWSTI Addict since: Aug 2007
did youre batt. die or go below opp. volts and do you have a cobb ap if so you may have to upload the map agian
Old 01-06-2008, 03:36 PM   #5
Car: 05 WRX STI
Fav Mod: Cobb Accessport
IWSTI Addict since: Nov 2007
As a diagnostic you could plug in the green connectors located on the drivers side under the steering column. Then turn your key to on not acc and you should hear the fuel pump prime among other things it does if the fuel pump doean't prime most likely it is the fuel pump or it's wiring. johnlude85 may be right with fuses but you may want to check the wiring that plugs into the walboro maybe it came loose. You battery is ok if it cranks over. So rule that out. Try those things and I will watch the post. G/L Leave no STI behind....
05SocalSTI is offline   Reply With Quote
Old 01-06-2008, 03:44 PM   #6
Car: grey 06 wrx sti
IWSTI Addict since: Dec 2005
how much gas did you have in it? what was the temp outside?
echipp is offline   Reply With Quote
Old 01-06-2008, 03:58 PM   #7
Car: 04 subaru sti
ok lets start from the top. battery is fine cranks over easily, checked fuses including the main fuel pump fuse under the hood they were fine. it has about a quarter tank of gas but its 52 degrees outside so i cant see the fuel line being frozen or anything like that. i cant run diagnostics because i have hydra. the whole flashing green dccd light is really scaring me though any other advice i will double check fuses but i defineatly do not hear the pump prime up at all
Old 01-06-2008, 04:11 PM   #8
Car: nbhp dc5
IWSTI Addict since: Dec 2007
yea... how much did you..?
dens_310 is offline   Reply With Quote
Old 01-06-2008, 04:21 PM   #9
Car: 04 subaru sti
quarter tank of gas and its 52 outside
Old 01-06-2008, 05:04 PM   #10
Car: 05 WRX STI
I assume you used the stock fuel pump wiring if so maybe something came loose check that. If that doesn't work put the stock fuel pump in and see what happens. This doesn't sound too tough. We'll figure it out sooner or later.
Old 01-06-2008, 05:14 PM   #11
Car: 04 subaru sti
dont have stock the fuel pump. ok i understand that i should just pull out my seat and check the pump and i will but dosen't anyone think that my dccd lights blinking has something to do with this possibly. they have never blinked before this.
Old 01-06-2008, 05:32 PM   #12
Car: 05 WRX STI
Check the fuses in the cab of the car. they are behind the little cubby right below you intercooler spray button. I bet one of those is bad it probably controls your dccd I'll try and replicate it with my subaru right now.
Old 01-06-2008, 05:56 PM   #13
Car: 05 WRX STI
replicated the problem it is SBF 5 in the engine bay I pulled it and nothing happens when I turn the car on, When I crank it, it just turns over. no fuel pump sound and the DCCD green light flashes; replace that with the 30AMP spare fuse and run it... let us know you should be good my 05 did the same **** yours is doing when I replicated it.
Old 01-06-2008, 06:00 PM   #14
Car: 06 Subaru WRX STi
Fav Mod: Valentine 1
IWSTI Addict since: Sep 2007
Send a message via AIM to shan mann
sounds like a battery problem to mee..
shan mann is offline   Reply With Quote
Old 01-06-2008, 06:07 PM   #15
Car: 05 WRX STI
or not the car turns over definitely not the battery
