Old 12-23-2007, 07:21 AM   #1
Fav Mod: Innovative Tuning
IWSTI Addict since: Jan 2006
Default Tech: How an intercooler makes you horsepower
I had a discussion with another tuner I'm friends with recently about intercooler efficiency and its relation to horsepower. I ran the numbers for an STi and I thought I'd share that information with the IWSTI community.
Someone on IWSTI asked how big a turbo you CAN run on a TMIC and the answers made me realize a lot of members don't seem to understand why people switch to FMICs. The answer is simple...the FMIC stays cooler on the street because it's not baking in the engine bay, it's bigger, and it has access to more airflow in most cases.
Now I'll explain how intake charge air temperature relates to the horsepower your car produces at a given moment. I'm going to make this as Subaru specific and realistic as possible so it has more meaning for you folks.
Lets start with a 70 F day because I know most people feel that when it's not real hot out, their TMIC works great. This car makes 525 crank hp. I'm using the APS D/R 725 intercooler simply because they have posted values for this piece.
Here are the numbers:
hp = 525
ambient = 70 F
compressor outlet = 415 F
intake manifold (post IC) = 105 F
Pressure Drop Across Core and all Ducting (psi) = 1.5 psi
Now the math:
Figuring out the efficiency of this intercooler:
Compressor outlet temp minus ambient temp:
415 - 70 = 345 F {this is the temperature gain from ambient to what comes out of the turbo}
Temp gain from turbo - temp dropped by intercooling + ambient temp = intake manifold temp.
345 - X + 70 = 105
X = 310 {this is the temperature dropped by intercooling}
Now that you have these numbers you can calculate the efficiency of the intercooler under these conditions:
Temp gain from turbocharging * cooling efficiency = temp drop from intercooling
345X=310
X=.898 = 89.8 % efficient
At almost 90% efficient this is working nicely.
Now...how does this affect power? The density charge affects power and density is related to temperature.
Here we go:
Dc = Density change
Dt = Compressor outlet temp
It = Intercooler outlet temp
Dc = [ (Dt + 460) / (It + 460) ] - 1
Dc = [ (415 + 460) / (105 + 460) ] - 1
Dc = (875/565) - 1
Dc = .549 (rounded to 3 places)
This means the intercooler made a 54.9% increase in density over the non intercooled charge. Some of the power increase this denser air causes is negated by pressure drop and flow restrictions in the core and piping do play a role as well. That said, this IC only has a rated drop of 1.5 psi across the core and piping under these conditions (26 psi, above listed temps, etc.).
For anyone wondering where the number 460 came from, it's used to convert our Fahrenheit temps to Rankine for this equation. More info here:
Rankine scale - Wikipedia, the free encyclopedia
NOW THE BIG QUESTION!!! How much power am I going making because of this intercooler?
HPr = Rise in HP
Dc = density change from the intercooler
Ap = Ambient Pressure (I'm using 14.7 for sea level)
Bm = Boost pressure at the manifold (26.1 psi)
Bc = Boost pressure at the compressor (27.6 psi)
HPr = Dc + 1 – [ (Ap + Bc) / (Ap + Bm) ]
HPr = .549 + 1 - [ (14.7 + 27.6) / (14.7 + 26.1) ]
HPr = 1.549 - (42.3 / 40.8)
HPr = 1.549 - 1.037
HPr = .512
That's a 51.2% increase in power which basically means you'd have around 350 crank hp if you removed the intercooler, but had similar flow restriction and pressure drop. Of course that's not realistic, but you'd still be under 400 hp without the intercooler. Sound too good to be true? It's not...as long as my Sunday morning math isn't off.
Now lets say this intercooler was heatsoaked because it's now a top mount sitting over the engine in the staging lanes before an autoX. Again I'm going to simplify here and say the post IC intake temp is all that changes from this. Instead of a post IC temp of 105, lets say the core is at hotter than before and it's not quite as efficient, so it only cools the air to 200 F.
Compressor outlet temp minus ambient temp: (THIS STAYS THE SAME)
345 - X + 70 = 200
X = 215 {this is the temperature dropped by intercooling}
345X=200
X=.58 = 58 % efficient
Here we go:
Dc = Density change
Dc = [ (415 + 460) / (200 + 460) ] - 1
Dc = (875/660) - 1
Dc = .326 (rounded to 3 places)
So now the intercooler only bumped the density charge up 32.6 %
The power difference?
HPr = Rise in HP
HPr = .326 + 1 - [ (14.7 + 27.6) / (14.7 + 26.1) ]
HPr = 1.326 - (42.3 / 40.8)
HPr = 1.326 - 1.037
HPr = .288
Now the intercooler is only making 28.8% more power than having no cooling at all (again assuming other things being equal).
The difference between the intercooler adding 51.2% power or 28.8% power is sizable in this case...about 75 hp.
I've kept these numbers realistic for a common situation many of you face. Now imagine it's 80 degrees out with a track temp of 120 F and you're at an autoX or drag event where you're hot lapping. Just think how enormous your losses can be when that intercooler gets hot!!!!
If you want to read more about intercoolers, check this other thread out:
http://www.IWSTI.com/forums/engine-p...ercoolers.html
Inn-Tune is offline   Reply With Quote
Old 12-23-2007, 07:33 AM   #2
aka: jnprn2003
Fav Mod: EFI Logics tunage
IWSTI Addict since: Feb 2007
Trader Rating: (13)
Default Re: Tech: How an intercooler makes you horsepower
Wow...vote for sticky!
RONIN is offline   Reply With Quote
Old 12-23-2007, 07:44 AM   #3
Car: '08 335xi Coupe
Fav Mod: Dinan Reflash
IWSTI Addict since: Aug 2005
CN: A better more efficient intercooler creates a denser air charge that is less likely to pre-ignite (detonation) upon compression. This creates a more oxygen rich charge in the cylinder requiring more fuel. The combination of more power and more fuel per combustion means more horsepower.
By the way, kudos to the OP for doing all that ****ling physics math that calculates why a hot intercooler and intake charge makes less power.
Tortfeasor STi is online now   Reply With Quote
Old 12-23-2007, 07:44 AM   #4
Non-Reformed Meth Addict
Car: '06 WRB
IWSTI Addict since: Feb 2006
+1 for a sticky. I may rethink my top mount setup.
Old 12-23-2007, 08:03 AM   #5
i eat cones
Fav Mod: intake
IWSTI Addict since: Oct 2006
Trader Rating: (21)
sticky for sure.
Old 12-23-2007, 08:22 AM   #6
Fav Mod: CP35r 440whp
IWSTI Addict since: Jun 2006
winnAr!
one reason I have a fmic.
one reason why I have the largest fmic on the market!
Old 12-23-2007, 08:28 AM   #7
Fav Mod: wingless and mis-fires
IWSTI Addict since: Nov 2007
Send a message via Yahoo to toogood
sticky ftw!
toogood is offline   Reply With Quote
Old 12-23-2007, 09:21 AM   #8
HowTo Contributor
Car: 06 STi
Fav Mod: 10.91 at 127.16
IWSTI Addict since: Mar 2006
Thanks Mike, I will be throwing my aps725 thats up in my attic on my car for my new setup this winter. I have rethought it and the advantages hugely outway the 30lb weight gain from it.
oh, and I have a headache now....to much thought for a sunday morning
jasv11 is offline   Reply With Quote
Old 12-23-2007, 09:54 AM   #9
Car: Blue, 06 STI
Fav Mod: Accessport
IWSTI Addict since: Aug 2006
Very interesting numbers. But there is one thing that is very important thing that you forgot to mention that is proven fact: FMICs look sweeeet. haha jk, but seriously really good info out of all of this.
WXRTSI is offline   Reply With Quote
Old 12-23-2007, 09:54 AM   #10
Car: Silver Euro 07 STi
Fav Mod: Crawford 35R
IWSTI Addict since: Dec 2006
Originally Posted by modaddict View Post
winnAr!
+1
Old 12-23-2007, 09:57 AM   #11
Inn-Tune,
Does humidity affect the power too? Lets say 80-90% humidity, if it affects the power at all. Thanks
Old 12-23-2007, 09:58 AM   #12
Car: 06 STI
Fav Mod: Stage 2 for now :)
Send a message via AIM to Chinky_Sti
nice info, but now my head hurts from all that math..
Chinky_Sti is offline   Reply With Quote
Old 12-23-2007, 10:43 AM   #13
Car: 06 OBP STi
IWSTI Addict since: Sep 2005
This is definitely some good info. Numbers. Nice. Looks like you did the math correctly to me. Not bad for Sunday morning. It only makes sense though that a FMIC equipped car would produce more power than a TMIC equipped car. How much a gain could one get from a stock turbo STi and a FMIC set-up? I can't really see it being too much, but I'm sure the tempatures will be quite a bit lower.
I'd love a FMIC set-up, BUT...to keep it cop-friendly, I think I'll stick to my TMIC. Of course this could change in the future...
Kind Regards,
Ryan
r12rex is offline   Reply With Quote
Old 12-23-2007, 10:49 AM   #14
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
IWSTI Addict since: Oct 2005
Send a message via AIM to 520
Very nice!
Old 12-23-2007, 10:54 AM   #15
Moderator
IWSTI Addict since: Jun 2007
Excellent information! Thanks!
