| | #171 |
| S204 Racer Feedback Score: 0 reviews Car: '10 VW GTI Location: Montgomery, Al Posts: 3,299
IWSTI Addict since: Apr 2006 | 45k miles on the stock turbo and a few track days and autocrosses... I haven't even looked at this filter. |
| | #172 |
| Junior STI Driver Feedback Score: 0 reviews Car: Silver 05 STi Fav Mod: Kartboy SS + Lathe Werks 1lb Stainless Knob Location: Kent,Wa Posts: 50
IWSTI Addict since: Mar 2008 | Would there be an increase difference in oil pressure by doing so? |
| | #173 |
| Grassroots STI Racer Feedback Score: 3 reviews Car: '05 WRB STi Fav Mod: GT52 Turbo Location: back in Abilene, TX :( Posts: 558
IWSTI Addict since: Dec 2006 | Unless you're reading oil pressure from right after the banjo bolt, you most likely would not see a pressure increase if it was starting to clog. I wouldn't think a semi-clogged banjo bolt would increase pressure enough for you to see it in an oil galley. I just pulled mine out after 35k miles. Clean as a whistle, cleaned it somemore and put it back in there. |
| | #174 |
| Professional STI Racer Feedback Score: 4 reviews Car: STI Fav Mod: CE28-N Location: SFV,SO-CAL Posts: 735
IWSTI Addict since: Nov 2005 | Good write up... |
| | #175 |
| S204 Racer Feedback Score: 2 reviews | if the turbo was broken because of this issue. is it covered by warranty? |
| | #176 | |
| Penguin Garage Certified Feedback Score: 31 reviews
Car: 32J GDFDYEH My Stuff: Subaru Parts Fav Mod: Thermal Mass Location: Chicagoland Posts: 4,506
IWSTI Addict since: Apr 2006 | Quote:
The TSB gives you ammo to use if your car is stock and maintained if your particular dealer doesn't want to do warranty work. If that happened, best bet would be to get in touch directly with SOA. | |
| | #177 |
| Spec C Club Feedback Score: 3 reviews Car: 04 Subaru WRX STi Fav Mod: Track days!!!!! Location: Vacaville Ca/Columbus Oh Posts: 1,021
IWSTI Addict since: May 2005 | Bringing this back again. Do you guys think that this would be causing me to burn oil if this is clogged? In about 3000 miles I go through 2 quirts of oil. 04 STi, the motor is pure stock, has 55,xxx miles on it and has been tracked 30 ish times. When I was tracking it that often I would change the oil after every track day. Also looking at the service bulletin it says that there are two union screw’s (banjo bolts) that have the filter in them but only indicates to do this to the ones marked C, the ones on the top. I need some input. I think I am going to do this tomorrow morning. Last edited by OrangeDot3083; 06-09-2009 at 05:54 PM.. |
| | #178 | |
Here is the TSB for the turbo oil feed filter: http://www.thel7.com/TSB/02-103-07.pdf This filter is located within the banjo bolt that connects the turbo oil feed line to the back of the right bank on the engine block. The possibility that a clogged turbo feed line is causing consumption is pretty slim. The turbo feed is low pressure. That doesn't mean you couldn't have a blown seals on your turbo but there would be other symptoms to point to this. Boxer engines are known to consume oil. Especially when certain synthetics are used. I suggest you look elsewhere first. | |
| | #179 |
IWSTI Addict since: Apr 2006 | There is a lot of misinformation and incorrect references/citations in this thread. it would be nice if a mod could clean it up to eliminate a lot of the confusion that is going on. |
| | #180 |
IWSTI Addict since: May 2005 | Ok so I went back and re read it slowly and then backwards. I did miss some thing, I now know what I need to take off. I will let you know how it goes and if it helps at all with the oil consumption. |
| Thread Tools | |
