| | #161 |
| Gold Member Feedback Score: 5 reviews Car: 2007 OBP/Gold Wheels My Stuff: Subaru Parts Fav Mod: Prodrive Mudflaps Location: Wilmington, DE Posts: 1,371
IWSTI Addict since: Apr 2004 | |
| | #162 |
| Junior STI Driver Feedback Score: 4 reviews | I want to share a point of view regarding the banjo bolt with filter located at the rear of the engine block on the turbo feed line. I think it is a bad idea to remove the screen here. The mesh holes in the screen are small but the area of flow is much larger. If you take the bolt off at the top of the turbo, you will see a very small oil feed hole in that bolt that provides a restricted oil flow to the turbo. If you take out the screen in the lower banjo bolt a small particle can then clog the small feed hole in the top bolt. However, the screen left in the lower bolt can trap many small particles without clogging before they get to the turbo feed hole in the top bolt. I remover the lower banjo bolt after about 30K miles and found hardly any clogging. i cleaned it with brake cleaner, blow it off with compressed air and put it back in. |
| | #163 | |
| Amateur STI Driver Feedback Score: 0 reviews Car: Legacy Spec B 2009 Fav Mod: Coming Soon Posts: 8
IWSTI Addict since: Feb 2009 | Quote:
| | #164 | |
| | #165 |
| Junior STI Driver Feedback Score: 0 reviews Car: OBP 06 sti Fav Mod: agile protune Location: east central PA Posts: 72
IWSTI Addict since: Apr 2007 | If you have theTMIC you must remove to get at the banjo bolt , FMIC not too bad of a job. I ended up using a mirror because you can't see what you are doing otherwise. If you bought the car new and are "anal" about oil changes you probably are o.k.,otherwise I would get it out of there.I have the Green turbo on my car which needs more oil than the vf39 so there was no question it had to go. Also be carefull not to twist and damage metal banjo fitting when loosening and tightening it would be easy to do. |
| | #166 | |
What is TMIC & FMIC ? | |
| | #167 |
| Junior STI Driver Feedback Score: 1 reviews | wow im just now seeing this thread and i got my old turbo replaced by the dealer due to oil starvation and now my new turbo is making like a scraping noise whenever i step on the gas or in boost. idk if i should go back to the dealer bcuz now im stage 2 and dont feel like going back to stock. I will clean the filter now and replaced it tomorrow when dealer is open. if it continue to make the scraping noise im going to take to the dealer. Does anybody have the link to the service bulletin on the filter so i can show the dealer. |
| | #168 |
| Junior STI Driver Feedback Score: 0 reviews Car: Pearl White 07 STi Fav Mod: Left foot, Right hand, then my right foot! Location: San Jacinto, CA Posts: 99
IWSTI Addict since: Jun 2007 | Top Mounted Intercooler, Front Mounted Intercooler |
| | #169 | |
This link has some good information: Forced Performance Turbochargers This one has some excellent photos to show different locations: Turbo oil-feed / AVCS line replacement | |
| | #170 |
IWSTI Addict since: Feb 2009 | Just a followup. The service manager said that my 09 has the turbo filter. I had a thought. Since the oil flows up and enters the top of the turbo, would there not be some backflow of oil through the turbo filter ias soon as the engine is shut down and oil pressure drops. Would this not back flush any debris off the filter. So if you are really good about using synthetic oil with frequent oil changes the filter should remain clean. Just a thought. |
| Thread Tools | |
