Old 01-03-2008, 08:18 AM   #46
IWSTI Addict since: Oct 2006
Default Re: An FYI to '07 STI customers I've tuned
My protuner says he does not alter the DA as this can be very dangerous... Does this mean my 07 will blow up eventuatlly. In otherwords, in order to make the 07's safe, does the DA need to be modified?
Varanont is offline   Reply With Quote
Old 01-03-2008, 02:58 PM   #47
Car: 07 OBP STi
Fav Mod: Lead Foot
IWSTI Addict since: Jul 2007
Originally Posted by RiftsWRX View Post
Again, all of the above. This is such a multi-faceted issue. Any authorized protuner has access to Cobb's forums, and specifically the Protuner venue. (Redirect). If your tuner of choice doesn't participate there, then they are missing out on a LOT.
Ask em.
Grynchmeister is offline   Reply With Quote
Old 01-03-2008, 04:27 PM   #48
Car: 07 sti
Fav Mod: whats a mod?
IWSTI Addict since: Feb 2007
find another tuner. it needs to be modified.
Old 01-04-2008, 05:31 AM   #49
My tuner (Hill from Agile Auto in Maryland) spoke to Christian and Christian supports his method of tuning the 07's... I am not a tuning person, so I do not know the different methodologies of tuning, but my tuner is one of the premier tuners in the mid atlantic, and he backs up all of his tunes and states his tune is safe. I guess there are several ways to prevent 07's from blowing up.
Old 01-04-2008, 10:44 AM   #50
Car: '02 WRX/'07 FIT
IWSTI Addict since: Mar 2004
Send a message via AIM to RiftsWRX
For fear of starting a debate of opinions on how well the factory timing system works, this is the reality of what happens.
The basic timing control systems have the authority to add in up to 5 degrees extra timing above and beyond what the tune would call for. That is one of the genesis (IMHO) of what is so wrong with the factory map once you get past the horrible stoich/full boost EPA parameters.
So, in short, what is happening? The car under various atmospheric, and fuel quality conditions can attempt to add a portion or the full amount of that extra timing in. If there is detonation it pulls it out like normal. So, there is a constant vicious cycle of small little jabs at the top of the pistons, etc.
That's a stock tune. Now, when you have a tune that is at 100% or even 95% of the limit for the octane, those extra 5 degrees of timing suddenly go from small jabs, to Tyson style upper cuts to your pistons.
Myself, and other tuners seem to recognize the benefit in trying to establish a CONCRETE level of control on the vehicle.
Other tuners want to understand and work with the wisdom of the Denso engineer (which is fine), and others have the opinion (myself included) that while the concept may have been in good faith, it's execution simply results in premature failure.
Take that for what it is, an opinion, and form a decision you find best for you.
Peace,
RiftsWRX is offline   Reply With Quote
Old 01-04-2008, 11:26 AM   #51
Car: 2007 STi LTD
Fav Mod: Stg. 2 with Knocklite
IWSTI Addict since: Apr 2006
What about the ability of the car to learn knock events with the stock map, IIRC the ECU does not apply any permanent learning or FLKC after 4000 rpms.So the car will keep knocking and knocking. Is that correct??? If so, I cant see how Subaru or Denso did that in good faith
BBBsti LTD is offline   Reply With Quote
Old 01-04-2008, 11:27 AM   #52
Fav Mod: CP35r 440whp
IWSTI Addict since: Jun 2006
Peace,
I think gabe has logged 7 or 8* added in.
OUCH!!!!!!!!!!!!!!
KABOOM!!!!!!
Old 02-18-2008, 07:58 PM   #53
OpenSourcerer
Fav Mod: ECU
IWSTI Addict since: Apr 2007
Hey it was only 5.
I support Jorge's method. The factory system used this way (removing the extra timing) works just like the previous EM or a WRX. Standalone systems don't have this crap. Some have autotune, but they they say to use it once to get the tune coarsely dialed in, then fine tune it from there.
Gabe
Old 02-24-2008, 12:10 PM   #54
Car: 07 SWP STi
IWSTI Addict since: May 2005
Hey guys, after reading this, I feel skeptical if I should even go stage 2 with the OTS map. Should I lay off, and not go stage 2 and wait for updates?
kyle sti is offline   Reply With Quote
Old 02-24-2008, 02:08 PM   #55
Car: 536whp of GT35R Love
I am another tuner that fully supports the method of zeroing the timing advance A & B tables. I have found that this is the only way to gain consistent and clean power from the 07 ECU. I, much like Gabe, have logged both of my 07 STIs and seen how one pull can result in X timing and another result in Y timing.
Nobody that I have met or heard of has been able to give 100% accurate information in regards to why the ECU does what it does.
For what it's worth, a very well known tuner did my 07 with a GT35R and left these tables in place. Gotta love 30 degrees of timing at redline with 29psi on a 35R. Go ringlands!
Remnex is offline   Reply With Quote
Old 02-24-2008, 03:23 PM   #56
Fav Mod: Gram Light 57F's
Send a message via AIM to jordanretro1223
Yeah that definitely tends to cause problems, haha.
As far as I'm concerned, until some of the tuners find out under what circumstances these tables turn on, if you will, there is no reason to have them contain any values other than zero.
jordanretro1223 is offline   Reply With Quote
Old 08-29-2008, 06:53 PM   #57
Car: Limited 07 Sti
Fav Mod: bel rx65.....K BAND
IWSTI Addict since: May 2008
Originally Posted by Dragicon View Post
used the cobb ots map for about 1 hour, car was so bad i reflashed back quickly.... interesting thread. To the OP, where do you work?
hey me too
STi Guru is offline   Reply With Quote
Old 08-30-2008, 06:26 AM   #58
Originally Posted by STi Guru View Post
hey me too
and yet you say this:
STi Guru
Car: Limited 07 Sti
Fav Mod: cobb ap
Trader Rating
Old 08-30-2008, 09:37 AM   #59
Car: Limited 07 Sti
Smile Re: An FYI to '07 STI customers I've tuned
STi Guru
Car: Limited 07 Sti
Fav Mod: cobb ap
Trader Rating
yeah....i put that on there when i first installed it..... then after driving it around and taking my accessport off i havent changed it.... but i will change it just for you
