Old 06-12-2008, 06:25 PM   #121
Feedback Score: 3 reviews
Car: CGM 05
Fav Mod: IAG 38mm EWG
IWSTI Addict since: Mar 2008
Send a message via AIM to 1loudsti
Default Re: The EWG FAQ (External Wastegate)
the reason for the lower pressure spring (from my new found understanding) is that if something fails you wont run no wastegate, basically it will default to 14 psi
a boost controller will simply regulate the amount of pressure the wastegate sees preventing premature opening
i may be wrong someone correct me if i am
1loudsti is offline   Reply With Quote
Old 06-12-2008, 06:44 PM   #122
Back to the oil burner...
Feedback Score: 4 reviews
Car: 2010 TDI Jetta
My StuffSubaru Parts
Fav Mod: 45+mpg
IWSTI Addict since: Feb 2007
Send a message via AIM to Kickstand
Actually you are right i believe. That was how my other ride was set up, just in case my boost controller failed, the wastegate still works. If they both fail, you have infiniboost!!!
Kickstand is offline   Reply With Quote
Old 06-13-2008, 07:52 AM   #123
Laughing at the squids
Feedback Score: 7 reviews
Car: 06 STi
Fav Mod: Buying a beater for Daily Driving
IWSTI Addict since: Nov 2006
The prodrive boost solenoid gives better spool, enables alittle more peak boost to be run, but primarily it's the faster spool . The Tial EWG springs can also be doubled up. Meaning, take the 1 bar spring which is the largest spring, and you can add a smaller spring inside of it to increase the rate. There are only 4 springs and they are colored. Red, green, blue and yellow which designates the rate. There's a vendor on ebay that sells just the springs. They are pricey($29) and nobody else I found carries the springs in stock. I was gonna double up My 1 bar spring plus the smallest spring when I switch to bigger turbo. But decided 14psi would be fine. The larger the spring rate, the harder the hit is when the EWG opens. So, if you road race alot or autoX with a moderated sized turbo, the smaller spring shouldn't send the back end of car around when it opens. Some guys have removed their ewg setup because of the abruptness of the opening. Could of just dropped to a smaller spring. Doing so reduces spool time some. A trade off.
Old 06-13-2008, 10:47 AM   #124
Car: CGM 05
maybe you guys can answer this.....if i was to put an mbc in does it go before, after or in place of the stock one?
Old 06-26-2008, 09:04 PM   #125
Feedback Score: 1 reviews
Car: WRB 05 WRX STi
Fav Mod: Disco Stick
IWSTI Addict since: Feb 2008
I don't know if this was posted or not cause I didn't want to read through all the pages but on GCG it says you would need to relocate your turbo in order to have a EWG. Is that correct with our stock VF39 or do we not need to relocate?
Toofast22 is offline   Reply With Quote
Old 06-26-2008, 09:08 PM   #126
Fav Mod: BOV and MBC
IWSTI Addict since: Mar 2005
You dont have to relocate your turbo, just buy an uppipe with an intergrated external wastegate.
Old 06-26-2008, 09:08 PM   #127
Car: 06 STi
Incorrect. Whoops, before Bill.
Old 06-26-2008, 09:13 PM   #128
Car: DGM 2008 STI
Fav Mod: Short Shifter
I have a question not sure if its been answered... I want to buy an EWG for my stock turbo, but i was wondering what size 38mm or 44mm, because soon ill be switching to a bigger turbo most likely in the stock location... But i dont want to buy a new EWG for this, so which is the best to get.. Thanks a lot
Old 06-26-2008, 09:15 PM   #129
Car: WRB 05 WRX STi
Thanks for the quick responses guys. Thats what I like to hear tho, don't want to move too much **** around. Not ganna be able to do all my mods tho till after college but would this actually be beneficial with a factory turbo, ap v2, and TBE? Once again sorry if these were already answered.
Old 06-26-2008, 09:19 PM   #130
Car: 07 sti
Fav Mod: whats a mod?
I beleive the solenoid controls the ewg, because you have to run a hose from the top of it to the solenoid.
Anybody know what spring I should run? Got the P&L kit and it came with the one bar spring. Currently running 23lbs on pump 25 on racegas.
i can get 23 psi at 70% wgdc on a 10 psi spring. a good solenoid helps a lot!
Privacy Policy
