| | #111 |
| Spec C Club Feedback Score: 6 reviews Car: 04 Aspen White STi Fav Mod: exhaust powered intake Location: Charlotte/Winston Salem, Posts: 1,477
IWSTI Addict since: Jul 2006 | What EWG kit will fit my Stromung DP (with seperate wg pipe)? |
| | #112 |
| Spec C Club Feedback Score: 3 reviews | im not completely understanding the wastegate spring question....what spring would i want to get for say 20 psi? |
| | #113 |
| Spec C Club Feedback Score: 1 reviews | |
| | #114 |
| Silver Member Feedback Score: 8 reviews
Car: 2006 OBP STi My Stuff: Subaru Parts Fav Mod: Snow Location: Alberta Posts: 1,947
IWSTI Addict since: Sep 2006 | As far as I know, the wastegate will open at whatever your spring pressure is at. So if the spring pressure is 14lb, your wastegate will open at 14psi. |
| | #115 |
| I'm Jim Halpert Feedback Score: 9 reviews
Car: 06 WRB STI My Stuff: Subaru Parts Fav Mod: EWG Location: Irvine, Ca Posts: 7,217
IWSTI Addict since: Apr 2006 | the ECU controls the wastegate just like the stock internal wastegate doesnt it? i was told the usual spring is a .9 bar spring which is what I have and what my tuner told me to get. I plan on running about 19 psi. |
| | #116 |
| Spec C Club Feedback Score: 11 reviews
Car: '05 Aspen White STi Fav Mod: Alcon 6 pots Location: Sacramento, Ca Posts: 2,057
IWSTI Addict since: Apr 2007 | No, the ECU doesn't operate the EWG, it is controlled by pressure. That is why the spring is important b/c if you get a very stiff spring and don't boost that high, the EWG won't open. |
| | #117 |
IWSTI Addict since: Apr 2006 | so clearly the stock internal wastegate is controlled by the ecu. it doesnt just open at a certain boost level. So how would the EWG hold the boost? say i install the .9bar spring in my car. If i run spring pressure i'll see 13 psi correct? but if i want to run 19 psi, how would that work? I guess the better question is what good is the prodrive boost solenoid if the wastegate simply opens at 13 psi? |
| | #118 |
| Spec C Club Feedback Score: 4 reviews
Car: Wingless '05 Fav Mod: BOV and MBC Location: Armpit of America Posts: 2,244
IWSTI Addict since: Mar 2005 | I beleive the solenoid controls the ewg, because you have to run a hose from the top of it to the solenoid. Anybody know what spring I should run? Got the P&L kit and it came with the one bar spring. Currently running 23lbs on pump 25 on racegas. |
| | #119 |
IWSTI Addict since: Apr 2006 | im kinda convused as well cuz i thought the boost solenoid goes to the wastegate. And if the wastegate is controlled by the solenoid, why does the spring even matter? maybe a ewg expert will chime in |
| | #120 |
| Spec C Club Feedback Score: 1 reviews | I'm under the impression that you want as close to your max boost as possible, otherwise the EWG will be open at lower rpm's creating lag, and it will be insanely noisy. Am I correct? |
| Thread Tools | |
