View Single Post
Old 07-03-2008, 05:22 PM   #3
RAPTR
Fav Mod: Tank the Terrier!
IWSTI Addict since: Jun 2006
Send a message via MSN to RAPTR
Default Re: RAPTR's 06 OBP STI
This pic below is of the Grimmspeed X-pipe. I wrapped the flex joint because is silences the "sowing machine" sound.
I would suggest this Crucial/Grimmspeed set-up to anyone who wants to maintain their "stock" appearence and doesn't want to
worry about a cracked header. I know cracking doesn't happen very often but I also wanted to utilizes the stock heat shields.
Below is a pic od the cusco mounts.
For the Next two images I decided to gather all the nessary parts for the inevitible AVCS line/Turbo oil feed line. I want to replace it before it fails.
If you want to know more please ask or check out http://www.iwsti.com/forums/engine-p...placement.html . Remember to get replacement copper seals for the banjo bolts and fittings. Also, in the shopping list below if you want a tighter fit order the 14" line over the 16" line but either one works. There are different places to order this stuff but on the list are url's where someone found what was needed.
RAPTR is offline   Reply With Quote
