Originally Posted by T3h_Clap hmm need to find out what camber you're running.
mount up your stock wheels, i'm curious how close that is to the strut with the 225.
the TiC's are not clearance friendly.
most coilovers are wider than the stock struts in the front and rear.
the rear you can do the camber bolt/plate trick and gain some clearance (and still get your "total" camber you're looking for).
another thing to do would be to find a WRX owner or another STi owner willing to test.
slap on the BBS's i'm curious on the clearance with those.
also what is your clearance to your trailing arm? |
Ok, I put the BBS in the rear and the strut clearance is very similar to that of the Volks. About 1 finger length (around .5 inches), I'd say slightly more room than the Volks. Trailing arm clearance is about 2 finger lengths, around 1 inch. Here's the pics:
Stock 17x7.5 BBS with 225's:
As you can see, I theres room for about 1 (around half an inch) of my gloved fingers:
Out of focus pic of the trailing arm clearance:
2 gloved fingers (Around an inch)
Originally Posted by token-negro If your looking at quality coil overs like you mentioned before Look at the V3's and the T2's along with the ZZyzx's and get them with rear plates. |
Thanks for the suggestions. The KW V3's are also high on my list. I've also considered RCE's T2's but I'm worried they may be a tad bit too stiff. I definately do want to research the subject a bit more though, as I'm not trying to skimp on one of the most important components on the car.
