View Single Post
Old 06-08-2008, 04:35 PM   #27
scoopman
Fav Mod: getting rid of my RX-8
IWSTI Addict since: Mar 2008
Default Re: Kenwood head unit 08 wallpaper
Kenwood responded and gave me something new to try.... The only problem is the file they attached (5mb worth) was named convert.dat, not one without an extension, as they describe below.
PM me if you want this file... No idea if it works yet, not sure if I want to reset all of my settings (again).
Here's what they say to do:
You need to add the convert program to your USB device. Follow the instructions below. Convert program is attached to this email.
To enter setup Mode, Press and hold FNC & EJECT keys, then press RESET Key.
· Release reset key, and hold FNC & EJECT Key until illumination activates.
· Connect the USB Thumb drive containing image file and convert program. All files must be in the root directory.
· There is no extension on the convert program.
· If you want to change the opening image to your own image (i.e., company logo), Press OEM Image.
· The OEM Image will be grayed out till files are seen on USB device.
· If you want to put original KENWOOD opening back, press KENWOOD image.
· Select the image you want to use.
· When the image is loaded, select Enter Your new opening will remain for few seconds and then switch to the Source Select menu.
Please feel free to contact us again with any additional questions.
scoopman is online now   Reply With Quote
